February 06, 2025, 10:32:13 AM
ECU reflash
9
10
11
Topic: ECU reflash (Read 62182 times)
jrjoe57
DesmoPorsche ECU reflash
Reply #135 on:
June 09, 2010, 03:21:20 PM »
So in the end are you satisfied with the DesmoPorsche ECU reflash? I am considering sending mine out or just getting the Fat Duc O2 emulator. 07 S2R Full Arrow no baffles.
07 S2R, Full Arrows, Rizoma Signals, Vizi-Tec Tail Light, CF Tail, Rizoma Rear Sets, Performance ECU, Woodcraft Clip Ons, Drilled Air Box, K&N Air Filter, CRG Mirrors, Carbon Beer Tray
vossy
South OZ
2007 S2R1000
Re: ECU reflash
Reply #136 on:
June 09, 2010, 08:22:55 PM »
Joe,
I got a reflash ECU from DesmoPorsche and installed it last week. Reset TPS and Trim, adjusted air bleeds a little and away I go! You do need to have a VDST or get a dealer to reset things.
I have no problems with recommending their service. I did all this and I live in Australia.
"Life's short" "Ride More"
jrjoe57
Re: ECU reflash
Reply #137 on:
June 10, 2010, 02:37:48 AM »
Thanks Vossy for the encouragement, how did you know what adjustments to make to the TPS, Trim and air bleeds?
vossy
South OZ
2007 S2R1000
Re: ECU reflash
Reply #138 on:
June 10, 2010, 05:18:53 PM »
The TPS will reset itself with the help of the VDST. (easy)
The trim was done by ear and a couple of short test rides. The trim starts off at zero on the computer, so you really want it to be slightly richer for better idle. Then I adjusted it to the point where it started to idle rough and backed it off a little, checked idle speed, test rode and adjusted some more till it felt right. The air bleeds were done using the VDST to firstly get the bike idling at the correct speed, rechecked and tweeked the trim and test rode again.
All up I went for 3 short test rides with slight adjustments inbetween and it runs great.
A mate who is a car mechanic helped me with the trimming by ear because that's what he does best.
hope this gives you some insight to what's involved.
there's lots of great info on here that can/will run you through the process better than I can explain.
scott_araujo
Re: ECU reflash
Reply #139 on:
June 10, 2010, 05:52:38 PM »
+1. The first time I tuned the bike I used a Gunson Colortune. It's a spark plug with a glass window in the top so you can see the color of the flame. Way cool toy and much cheaper than a gas analyzer. Since then I've gone to tuning by ear as above: richen up slowly until it stumbles and then back off a bit, then a test ride to make sure. As said, once you connect to the ECU it's all fairly easy.
Scott
♣ McKraut ♣
touched by his noodly appendage
Re: ECU reflash
Reply #140 on:
June 11, 2010, 01:20:14 PM »
made the changes to the keyspan usb adapter as suggested from the faq page on the technoresearch site, and the vdst is now communicating decently with the ecu. just to clarify though, the trimmer value is saved when you have the screen below, right (and therefore you know that the chip was truly flashed to DP spec)? also what trimmer value are you guys using?
now to troubleshoot why the gauges are displaying max air temp and max speed:
2001 M600 Dark
2005 S2R Dark
2001 M750
1996 900 SS/SP
2005 S4R
- Dallas, TX
dbran1949
2007 S4RS Black Termis
Re: ECU reflash
Reply #141 on:
June 11, 2010, 02:03:50 PM »
I have no direct experience with VDST but typically when a sensor reads maximum values it means it is not connected i.e. the input to the measurement device is floating
scott_araujo
Re: ECU reflash
Reply #142 on:
June 11, 2010, 04:23:41 PM »
Yes, trimmer value is saved. If you're unsure go to another screen and come back, it will reload.
I'm about 13 I think BUT don't worry about that too much. Get the bike running right and don't use someone else's setting EXCEPT that if you're way off something might be wrong.
Scott
♣ McKraut ♣
Re: ECU reflash
Reply #143 on:
June 12, 2010, 05:05:25 AM »
just to verify everything worked properly with the software and cable etc, i hooked it up to a friend's 848 (with a genuine DP ecu)... gauges worked properly, including speedo and air temp (his read 80 something). also, i took a look at his trimmer setting, and it was set to 35... but his bike had been properly tuned at AMS. do dealers have access to the full fuel mapping across all throttle settings? i put mine to 30 (it was indeed saving the 15 value from earlier) for a quick ride home and my gf followed behind me and said it shot flames a couple times on decel. so...maybe i need to back that off a bit.
2001 M600 Dark
2005 S2R Dark
2001 M750
1996 900 SS/SP
2005 S4R
- Dallas, TX
booger
Re: ECU reflash
Reply #144 on:
June 12, 2010, 05:27:48 AM »
I don't have an S4R but I do have a DP ECU and the trimmer value according to VDST is set at 15 currently. I have no running issues. I think +30 may might be way too much.
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
♣ McKraut ♣
Re: ECU reflash
Reply #145 on:
June 12, 2010, 06:11:38 AM »
Quote from: bergdoerfer on June 12, 2010, 05:27:48 AM
yeah, definitely. the friend i borrowed the vdst from has a 1098 and says that he likes his at 15. so i may try 15 for a bit and see how that goes.
2001 M600 Dark
2005 S2R Dark
2001 M750
1996 900 SS/SP
2005 S4R
- Dallas, TX
vossy
South OZ
2007 S2R1000
Re: ECU reflash
Reply #146 on:
June 14, 2010, 04:59:09 PM »
I've just set mine up last week and it's trimming is set at +20. Runs beautifully.
('07 S2R1K)
I'm glad you've had some headway with your set up McKraut.
♣ McKraut ♣
Re: ECU reflash
Reply #147 on:
June 15, 2010, 05:29:59 AM »
well...i think so. though in a thread i have in tech (
http://ducatimonsterforum.org/index.php?topic=39013.45
) i'm being told i may need to actually be using TPS adjustment screws to actually reset the TPS, not just a software thing with the VDST.... so i guess after work tonight i'll have to get out a flashlight and go hunting for those screws... just when you think you're making headway with something...
also i need to figure out why the air temp sensor (and speedo) aren't registering on the vdst. fun times.
2001 M600 Dark
2005 S2R Dark
2001 M750
1996 900 SS/SP
2005 S4R
- Dallas, TX
lofty55
Re: ECU reflash
Reply #148 on:
June 23, 2010, 06:11:52 PM »
Any new info out there?
Im about to start an ECU adventure of my own. Im shopping around for a full system, i plan on getting the TPO Beast-R intake kit also. I will definitely need my ecu flashed. I sent emails to desmoporsche and motowheels inquiring about a map for this setup. After the flash is done it looks like all i need is VDST to finalize things. Easier said than done. Has anyone accomplished this successfully? Vossy, your story is the light at the end of the tunnel. I think you have the same bike as me too.
Im in the Los Angeles area if anyone has VDST and is willing to let me use it.
Bike is '07 S2R1k
Hope we get this mess sorted out. Every shop i call locally uses a different method for exhaust mods on my bike, Eh...
Last Edit: June 23, 2010, 06:28:45 PM by lofty55
This is more fun than standing still at a radiohead concert.
'07 S2R1K
'02 998
vossy
South OZ
2007 S2R1000
Re: ECU reflash
Reply #149 on:
June 23, 2010, 07:28:45 PM »
I'm sure things will be fine with your ECU re-flash.
If you can't borrow a VDST (must be the one for your 5AM ECU), you really have only two options.
1. buy your own VDST, well worth it if you plan on keeping the bike for a while.
2. take it to a dealer who can set it up for you.
I'd be keen to hear how you go with it all.
good luck!
9
10
11
