February 05, 2025, 05:06:21 PM *
Pages: 1 2 [3]   Go Down
Author Topic: Rear brake and Shift levers  (Read 4510 times)
loves ze desmodromics.
« Reply #30 on: February 10, 2010, 04:15:27 AM »
can't the giles lever be config'd for either standard or reverse... yep, checked. it can be reverse pattern.  still have the con-rod though.
Yes, all the aftermarket and even stock rearsets can be configured for reverse my flipping over the linkage at the shaft - the only interference problems arise when using an Evoluzione slave, which uses longer bolts. (You can search DucatiSpot or Ducati.ms for images of a guy who machined down a brand new evoluzione so he could still do linkage-based reverse shifting... instead of buying a reverse shifter - WHY is beyond me).
Removing the linkage gives a really nice, positive feeling. No slop from the various connections.
Pages: 1 2 [3]   Go Up
