January 19, 2025, 11:50:24 AM *
Pages: 1 2 [3]   Go Down
Author Topic: my kickstand is leaking oil.  (Read 12329 times)
Privateer
« Reply #30 on: February 11, 2010, 05:41:38 PM »
so whatever DOT 3 or 4 fluid at the local auto parts place is fine?
« Reply #31 on: February 12, 2010, 02:26:46 AM »
I'd stick with DOT 4
Privateer
« Reply #32 on: February 12, 2010, 04:10:24 PM »
cool, thanks.  The desmotimes book says 3 or 4, but I'll go with the 4.
May I should take pics and do a tutorial
Privateer
« Reply #33 on: August 24, 2011, 06:48:54 PM »
So today when I was leaving work I noticed a spot of oil under my bike.  I'm not the only bike that parks there so I didn't think much of it.
Got home without incident, and went out a couple hours later to lube my chain.  Noticed the same spot of oil and a little oil on my front sprocket cover.  OK.  not good, but not the end of the world.  Probably the o-rings on the push rod again.
Unbolted the clutch slave (evoluzione) and about a teaspoon or two of oil poured out.  it was all trapped in the hollow of the piston.  OK.  that's not making me feel better.
So 1) what's the lifespan of those o-rings typically?  2) is that a lot of oil to be worried about?
Ddan
Some of my best friends are whores
« Reply #34 on: August 25, 2011, 02:38:33 AM »
Was it oil or brake fluid?
                    flogged successfully  NHMS  12 customized.  Twice.   T3 too.
Ducati Monster Forum at
www.ducatimonsterforum.org
Privateer
« Reply #35 on: August 25, 2011, 06:09:39 AM »
Oil.
Ddan
« Reply #36 on: August 25, 2011, 06:15:08 AM »
Back to the beginning:
http://www.ducatimonsterforum.org/index.php?topic=34435.msg599639#msg599639
NorDog
I don't feel like a
« Reply #37 on: August 25, 2011, 06:18:03 AM »
Mine does that when the slave leaks.
Easiest way to track down any fluid leak is with aerosol foot powder.
Clean with detergent and water. Let dry, and cover with the powder. The source of the leak should be evident, or at least you can eliminate sources.
I tried it, and it works great.
My oil leak is coming from from underneath my little piggie.
 Wink
Privateer
« Reply #38 on: August 25, 2011, 06:41:04 AM »
yes i'm well aware of how to track down where it's leaking.  Based on what I found once I took everything apart it's pretty clear to me I'm getting blowby on the pushrod.  My questions were:
Ddan
« Reply #39 on: August 25, 2011, 06:54:02 AM »
I might have replaced mine sometime in the last 40K miles, I don't recall.
I'd worry about any oil dripping potentially on the rear tire.
BK_856er
2007 M695; 2004 749s
« Reply #40 on: August 25, 2011, 08:40:45 PM »
Just another datapoint....the pushrod o-rings the factory installed on my M695 started leaking at about 5k miles if I remember right.  I now keep some on hand and replace them whenever I have the rod out and it's been a while.  Not that they need replacing each time, but they're cheap and I have zero tolerance for oil leaks.  I also try to inspect/clean the bore in the case and lube the o-rings with a little lithium grease during installation.
BK
Pages: 1 2 [3]   Go Up
