OIl leak & So glad I found this
Started by metallimonster, May 30, 2008, 11:25:05 AM
Quote from: sbrguy on February 02, 2009, 06:19:01 AM
damn stu, that is one early time to be up on  the west coast.
when i was doing this i was thinking "crap, i ripped the damn rubber seal"  but overnight didnt' leak one bit.  so its all good now.
also put on that hex bolt drain plug from monsterparts.com works great, though think i will have to tighten that up a little more, did it with a torque wrench to the spec 40nm but have to check later with a better wrench.
See the hell I go through for you guys?!?  YOU try being a moderator on the Tech board and see if you can sleep at night?!?!?  (j/k!)
Quote from: Norm on February 02, 2009, 06:10:32 AM
I use PerForm filters, hand tight, zero problems.
That's an option too.
