February 05, 2025, 08:13:04 PM
14T sprocket vibrations/shaking
Topic: 14T sprocket vibrations/shaking (Read 5583 times)
Spidey
Crashin' mofo
Re: 14T sprocket vibrations/shaking
Reply #15 on:
February 25, 2010, 02:49:50 PM »
Quote from: iamhybris on February 24, 2010, 10:37:56 AM
I realigned my rear axle and checked the chain tension and I'm still getting the vibration. Later today I will loosen up the chain even some more to see if it takes care of it. Those axle alignment plates are so useless it's a joke. I don't know why they even bother putting them on when they bend the first time the axle nut is loosened.
I'm going to measure the axle from the pivot point on the swingarm this time to make sure it's straight.
I'll post up after this adjustment. For the ride home today....vibrations...
Yeah, the alignment marks are always off. I get better alignment just by eyeballing from the rear sprocket down the chain to the front sprocket than by using the marks on the adjusters.
Swingarm pivot works. Or you can just lay a straightedge (I use a piece of bar stock) flat on the rear sprocket and see if the chain follows it. I generally eyeball and then use a straightedge to confirm.
WetDuc
AKA iamhybris
Reply #16 on:
February 26, 2010, 09:45:15 AM »
Measuring from the swingarm pivot was a bit off because my DSS is asymmetric, it forced the tape measure to bend out of straight. I measured from the rear end of the swingarm to the axle and loosened up the chain. The vibrations were less noticeable, but maybe still there, or maybe I'm just kind of expecting to hear it.
I think I may have killed my chain on the first 50mile ride after the sprocket change when it was just waaaaaaaaaay too tight.
alienfocus
Reply #17 on:
February 26, 2010, 06:37:03 PM »
Let me see if I can help a bit here. I myself run a 14 on my S2R800 (15tooth really does suck) and i did notice a vibration with the same rpm range you mentioned. I had my VERY trusted tech look at (20plus years as a Duc wrench) the chain and it was fine in stock required tension. I see this sometimes in my job as well....I work in the cycling industry as a race mechanic for a drive-train component maker. The vibration we get is smaller gears (11-13 tooth) under low to medium torque and then goes away as the rpm rise or you go higher in the gear ranges.
The reason we feel is that the chain is wrapping around the cog in slightly tighter angles (possible more chain noise and vibration from such frequencies in a small area) and mix that with the fact the cog is now smaller in diameter (from the stock 15) so there is less mass on the end of that rear axle (drive shaft-out put shaft of the engine) but it has to handle the same amount of engine frequency, torque and vibration.....The noise can be felt and heard. Change the belts on your Monster and they will whine and vibrate a tad when breaking in especially if you run open or no covers.
My Monster has run most of its life on the 14 (my first mod after 500 mile service)and after a few rides you get used to it.
Chain lube can play a huge factor as well. Thicker lube isolates noise and vibration just like sound dampening material in a car...i use spray wax type lube and my drive-train is all but silent and doesn't sling off. (an issue we see as well in cycling)
I would also say is that if your chain had time on it and then you switched to the 14..your chain stretch may be just enough to cause conflict. Try the 15 again and make sure its the 14 making the fuss. I run a Ducati steel 14 and its fine...if yours is after market else where then maybe a pitch conflict in the new cog and your used chain. Hope this helps and wasn't too long winded...and made sense [moto]
battlecry
On a silver black phantom bike...
Reply #18 on:
February 27, 2010, 06:29:50 AM »
Alienfocus is on to it. The stock gearing for your bike is 15/42, which gives you a fractional ratio (2.
. You changed to 14/42 which is a whole ratio of 3. You try to avoid whole ratios because you want to spread the wear over different sprockets. With a whole ratio, every few revolutions the same chain link will hit the same sprocket tooth. With a fractional ratio, it takes many more revolutions.
Besides the periodic wear, the whole ratio will make it more susceptible to set up periodic vibrations or harmonics in the chain/sprocket system. I'm running a 14/42 also, and besides making sure everything is aligned, tightened to spec, and chain in good condition and loose, not much else you can do.
14 tooth sprockets are talked down because they can wear the plastic spacer in the front of the swingarm, and in extreme angles, even the swingarm. Here is a condition where the plastic spacer can work as a vibration damper as it gets worn down. Make sure you have some plastic there.
Reply #19 on:
February 27, 2010, 07:03:15 AM »
How old is your chain?
WetDuc
AKA iamhybris
Reply #20 on:
February 27, 2010, 11:10:34 AM »
I have about 5000 miles on my chain now. I'm sure the chain isn't too tight, I triple checked.
I really appreciate the lengthy explanations, I agree this seems to be the issue and it makes perfect sense. It's nice to know some others have experienced the same thing and that it might not be my newbie user error.
I'm thinking I'm just going to get used to it for now and get a new chain and sprockets eventually and go up a few teeth in the rear sprocket instead this time. I'd like to get as much life out of my current setup as I can before I spend the $$$'s to replace everything, though.
Reply #21 on:
February 27, 2010, 01:48:04 PM »
5K mile old chain and a new sprocket can be the problem, particularly if you change sprocket size. What battlecry is referring to is hunting, partial hunting and non hunting gears. A hunting gearset is when any tooth on the smaller gear will come in contact with all the teeth on the bigger gear, considered best for wear. This ratio, for example, 42:15 cannot be reduced to an even number. Partial hunting is when one tooth on the small gear will contact some of the teeth on the bigger gear, but it will take more than one revolution of the bigger gear, for example, 42:14, which would take three revolutions of the big gear. Non hunting is when one tooth of the small gear comes in contact with some of the gears on the big gear in one revolution of the big gear, for example, 60:15. Add a chain into the equasion and it is unlikely you would wind up with any combination that would be a non hunting or a partisal hunting of any consequence.
WetDuc
AKA iamhybris
Reply #22 on:
February 27, 2010, 01:56:21 PM »
To specify more, I changed the sprocket to 14T at 4500miles and have about 5000 total now. I might put the 15T back on if I can't take it, but I hate that stupid sprocket so much.
I can usually avoid the vibrational section of the rpm range in the lower gears, but up in 4,5,6 it becomes more noticeable. If the chain is dead, I'm thinking it's not going to get better in a hurry. If that is the case, I'd rather wear it down until I take the bike in for the first service and change it then...
