It's happened again...guide(s) shot
Started by Mr Earl, February 21, 2010, 05:54:55 PM
brad black
Brad The Bike Boy
http://www.bikeboy.org
chenzo9
Because it has been hard to start and ocassionally it stalls on me at a stop. So I brought it into Ducati and had it checked and they determined that the guides were bad. Any suggestions?
Vinnie
chenzo9
Quote from: Armor on January 06, 2012, 09:19:58 AM
Vinne,
Why do you need the valve guides replaced?
The bike was hard to start and ocassionally stalls at a stop. I brought it into ducati and had it checked. They determined that the guides were bad and it happens to a lot of the new DS motors. Amy suggestions?
Quote from: chenzo9 on January 13, 2012, 03:10:52 PM
Vinnie
Sorry to hear about your valve guide problems. That's a cool looking bike in your avatar. You should post up some pictures in the "bikes of the DMF" thread. So did you transplant a DS1000 into a 2000 Monster chassis?
avizpls
Hmm...they sell 39 and 44mm valves there. What do you suppose one would do with those?
#11
Quote from: avizpls on January 13, 2012, 05:19:22 PM
Assuming they're 8mm stems, you could pretty much fix the crappy 900 valve seat profile.
Or at least salvage a set of heads.
Ca-Cycleworks has 40/45 sets that would likely enable a complete fix.
avizpls
Wow but how much further up in would they be seated? I picture intake vs exhaust valve clashes! Hw doesn't that happen?
What does a good profile look like then? I know the 900s are...shall we say simple, but so bad that you need an extra mm or even two to recut a better shape?
#11
I'm pretty sure I've got a set of M900ie heads with cams, still assembled, I'll check how much clearance there is between the valves on overlap.
The OEM seats have a pretty nasty 'step' in them, my cylinder-head guy said it really kills flow at low lifts, and larger valves and cutting the seats to match would help a *lot*.
jerryz
Colisbro valve guides are also much superior to standard ducati ones
