February 21, 2025, 10:51:57 AM *
Pages: 1 [2]   Go Down
Author Topic: Simple Green Automotive  (Read 4377 times)
g6
« Reply #15 on: February 28, 2010, 04:44:27 AM »
I have found that cleaning with the regular Simple Green is good for chains and other Steel parts but not aluminum as it reacts and causes discoloration on finished parts.
Wheeeeeeeeeeee
trekssl
« Reply #16 on: March 01, 2010, 06:01:05 PM »
Simple Green Aircraft is safe to use on aluminum and just as effective as the regular formula. I bought a gallon of the concentrate at Sacramento Sky Ranch for $18.95
07 S2R1000
DucatiTorrey
My wife's super hero is my
Industrial Designer
« Reply #17 on: May 12, 2010, 06:56:23 AM »
we recently moved to Colorado, long road trip in the cage. But, on the way the simple green leaked! and onto my chemical gloves no less! Wow, crazy ass sh!t
i cant believe is would do this to chem gloves!
  - real place
Monster Dave
« Reply #18 on: May 12, 2010, 07:08:33 AM »
I've used a 50/50 solution with basic Simple Green to clean under the hood and it's done a great job.
Loyalizer
SomeKindOfWonderful
« Reply #19 on: May 12, 2010, 07:35:32 AM »
Anyone try AWESOME from the 99 Cent store?
Look! up on the Highway! My word! It's insane! No! It's a Monster....
Monster Dave
« Reply #20 on: May 12, 2010, 07:45:54 AM »
Most things that I've found at that 99 cent store are less than awesome.....good but now quite "awesome".  cheeky
WarrenJ
« Reply #21 on: May 12, 2010, 08:31:50 AM »
Whenever you want to coat something, whatever you clean it with, you want to look for  a "water break free" surface.  That means when you run water over it, it flows in a continuous thin sheet over the surface.  If the water film "breaks" and leaves dry areas, the surface is still contaminated and can be an issue for coating.  We used to pre-treat and paint 2000 wash machines per day and that was something we always watched when the parts came out of the last rinse before coating, that the water ran off in an even sheet and did not "break" as it was an indication of oil or contamination on the steel.
Having 2000 wash machines in crates in the warehouse with the paint coming off in sheets is not fun.  Take my word for it.
A product I tried recently is "Spray Power" from Crown.  It is relatively inexpensive and worked real well for cleaning gunk from my bike, including aluminum areas.  Its water soluble and even cleaned the wheels pretty well.
http://www.crownspraypower.com/Motorcycle_Cleaner_s/24.htm
zooom
« Reply #22 on: May 12, 2010, 10:25:50 AM »
I have used that automotive cleaner degreaser version of Simple Green, but I find that the Castrol Super Clean worked better!!!
2010 KTM 990 SM-T
For $50 you can touch my
« Reply #23 on: May 12, 2010, 11:47:41 AM »
It got my mouse spotless.
DucatiTorrey
Industrial Designer
« Reply #24 on: May 12, 2010, 03:42:36 PM »
i also dilute my simple green, not this bottle though (yet), and as i use it i continuously fill it to the top with more water.
  - real place
Pages: 1 [2]   Go Up
