Paint the engine, is it possible?
Started by MortenChristoffer, February 22, 2010, 03:47:15 AM
slowkitty
I smell an alternative to doing it myself.... will begin new piggybank fund with email to DP when its near full.
djrashonal
Quote from: ducpainter on February 24, 2010, 03:12:20 AM
That's not sound.
The stain isn't an issue.
Here's the issue.
Paint won't stick well to untreated aluminum. If you remove the factory paint you need to either use an epoxy primer, a self etching primer, or chemically treat the aluminum. That's why I leave it if possible.
What's the best way for it to stick after it's cleaned up? just leaving the original on and a light sand? Everyone is talking about Air cooled, is there any difference for a water cooled?
01 SSSSSSS4 - Sold
'09 Triumph Bonneville
S2R800 dark - searching for
Quote from: djrashonal on February 25, 2010, 11:39:03 AM
Sand out defects...scars scratches etc and prime or treat any bare aluminum. I like to use a red scotch-brite to abrade where you can't get a piece of paper, which really isn't much on an engine.
If you like insurance you can use an adhesion promoter and then spray with a 2 part urethane. It holds up well to solvents and the normal surface temps of air cooled engines.
There is no difference for water cooled.
djrashonal
Quote from: ducpainter on February 25, 2010, 12:04:14 PM
Thanks  [thumbsup] where can one find said 2 part urathane? i was just going to use a high heat aerosol from lowes. I'm going for a blending look, so i want it as flat as possible.
01 SSSSSSS4 - Sold
Quote from: djrashonal on February 25, 2010, 12:55:28 PM
Rattle can isn't solvent...gas oil chain lube resistant.
You can go to most auto body supply houses and buy an aerosol kit that has a 2 part paint in it that they fill there with exactly what you want. You pull a tab to mix all the components and then you have a few hours to use it.
Tell the guy at the paint counter you want flat black.
i sprayed my valve covers with that VHT engine paint. its suppose to be pretty good against temps up to 550, oil paint and gas resistant.
it was stripped down to the bare aluminum and i didnt use any primer ( didnt know any better). and it came out really good. never stripped or anything. I only had it on there for a few months so no idea how long it will last.
Quote from: He Man on February 25, 2010, 01:58:34 PM
i guess it comes down to definition when using the word resistant. :-\
If you use the Duracoat, you don't need the adhesion promoter.  I blasted the jug fins on the GTL down to the metal, cleaned it with the Lauer solvent and compressed air, and applied the Duracoat mix with a Preval aerosol.  After 3 years its still there.  I believe the Duracoat is an epoxy type paint.  Pretty much resistant to everything -- gas, oil, carb cleaner, etc.
Quote from: ducatiz on February 26, 2010, 02:36:58 AM
The only issue with an epoxy would be UV exposure.
You park your bikes inside. Left outside an epoxy will UV degrade in a short time.
On steel rust would appear within a year or so depending on film thickness.
Aluminum would corrode.
Quote from: ducpainter on February 26, 2010, 03:17:56 AM
i know that's an issue with epoxy, but not a problem with Duracoat.  maybe they don't use epoxy, that is just my guess.  it's a two-part thing and smells like it.  it's a proprietary formula, so no idea what they use.
Quote from: ducatiz on February 26, 2010, 06:30:02 AM
If it adheres to bare metal without treatment it almost has to be epoxy based on my knowledge.
Have you left anything done with it outside for extended periods?
Quote from: ducpainter on February 26, 2010, 07:24:48 AM
I am thinking you are right, because they sell a UV resistant topcoat and a separate UV resistant hardener.
I had seen it before, but it didn't register, so it's definitely epoxy based...
Quote from: ducatiz on February 26, 2010, 07:37:31 AM
The UV resistant stuff is most likely a poly/urethane of some sort. The stuff they have today is amazing with regards to hardness/chemical resistance.
greenmonster
Anyone who considers painting seriously (=removing engine), think about it at least FIVE times first.
Requires redicolous amount of time, sandblasting, masking etc. There is alot of cavities, fins etc..... [roll]
M900 -97
MTS 1100s  -07
