February 23, 2025, 04:52:54 AM
Please Help
Frameless ducs?
Topic: Frameless ducs? (Read 7234 times)
gm2
Re: Frameless ducs?
Reply #15 on:
February 23, 2010, 08:14:21 PM »
Quote from: NorDog on February 23, 2010, 01:19:57 PM
Forgive me for picking fly shit out of the pepper, but it looks to have two frames; one in front and one in back.
there's an airbox, a swingarm, and a subframe. the engine is bolted to all three. if the engine weren't there, there would be nothing to connect them to.
generally a frame is something the engine bolts
into
.. something that, er, frames it and the other major pieces.
if you want to get peppery about it, the engine is the anti-frame.
Like this is the racing, no?
superjohn
Re: Frameless ducs?
Reply #16 on:
February 24, 2010, 02:40:29 AM »
Quote from: FastAndLight on February 23, 2010, 04:25:08 PM
I think that is the point. The engine joins together the two monocoque frame sections. It looks pretty awesome to me. And light. And light is fast.
I, for one, welcome our semi-monocoque overlords.
+1. Despite the inevitable wave of "Ain't got no trellis, it ain't no Ducati" I think it's a great idea for the superbikes. Get that weight down and make 'em faster.
That said, it wouldn't make a naked as pretty.
abby normal
jesus is coming ... look busy!
Re: Frameless ducs?
Reply #17 on:
February 24, 2010, 04:37:09 AM »
as someone mentioned, that's pretty much what the vincent had. and not too different from
the Britten either. not bad ideas, but not new either.
1990 851 bp
2004 S4R
1997 YZF 1000R
1987 NT650
2010 BMW s1000rr
2013 848 evo corse se
Re: Frameless ducs?
Reply #18 on:
February 24, 2010, 04:44:50 AM »
Quote from: superjohn on February 24, 2010, 02:40:29 AM
No trellis here...it's undoubtedly a Duc...says so right on the tank.
sbrguy
Re: Frameless ducs?
Reply #19 on:
February 24, 2010, 04:58:13 AM »
think about it, it would probably make the "perfect" naked bike.
why? because the headtube to engine part doubles as an airbox so you can hide also ellectronics and such up there even better than a monster once the tank is on, the subframe and rear swing arm are there but basically they are hollow too so you can hide more things up in teh subframe area connection, meaning all that is left is literally the engine hanging down now. so in a way all that you can see is the engine block and the radiator in front.
that two frame design probabgly if they tried would make an engine look very very clean for a naked bike. with any luck in 10 years maybe that carbon monocoque frame will be just as normal as the steel trellis frame on road bikes. we can only hope.
Scottish
Balls!
That's thinkin' with your dipstick Jimmy!
Re: Frameless ducs?
Reply #20 on:
February 24, 2010, 07:04:13 AM »
If you look at our Monster frames or even better, the frames used on the SC and I believe it was the old SS's as well, all that is really cut out is about 9 inches of tubing that connects the top rail of the frame from front to back. Then they reworked it to connect to the cylinderhead instead. So it may be a technological step forward and superior in many ways I have no doubt, I do doubt however that weight savings would be of any note assuming both designes used similar size and material in the tubing. In fact with the extra gussetting that may be required for the frame and engine there may be no weight savings apples to apples.
FastAndLight
Re: Frameless ducs?
Reply #21 on:
February 24, 2010, 10:42:06 AM »
Quote from: Scottish on February 24, 2010, 07:04:13 AM
I think it is likely lighter and stiffer, or else they wouldn't have done it. If the CF is properly laid and shaped it can be significantly lighter than the comparable strength Al frame would be, much less a steel one. Also, they were probably able to make a significantly more rigid frame while maintaining low weight which will allow the bike to handle that much better.
NorDog
I don't feel like a
Re: Frameless ducs?
Reply #22 on:
February 24, 2010, 10:56:26 AM »
Plus, I would think that any weight savings would be up high, so, less weight up high would equal a lower center of gravity which also helps in the handling department.
Buell calls it "centralization of mass".
danaid
Re: Frameless ducs?
Reply #23 on:
February 24, 2010, 11:56:01 AM »
The article did mention that the patent was for mainly the GP9 and 10 technology, which we could all see down the road as standard race bike technology, but I wonder if this patent has anything to do with the new Moto GP rule changes which gives weight and fuel bonuses to the manufactures whose bikes use a more "production based" design. Maybe we'll see a new batch of limited edition Desmosedicis based street bikes on the GP 9 and 10 design?
Detroit used this tactic in the early days of drag and stock car racing to allow mega engines and special parts on the track.
Last Edit: February 24, 2010, 06:08:36 PM by danaid
11' 1198SP Black
09' 1100S Red
09' 696. Red first Ducati (sold)
DucatiTorrey
My wife's super hero is my
Industrial Designer
Re: Frameless ducs?
Reply #24 on:
February 24, 2010, 12:04:55 PM »
Quote from: danaid on February 24, 2010, 11:56:01 AM
The article did mention that the patent was for mainly the GP9 and 10 technology, which we could all see down the road as standard race bike technology, but I wonder if this patent has anything to do with the new Moto GP rule changes which gives weight and fuel bonuses to the manufactures whose bikes use a more "production based" design. Maybe we'll see a new batch of limited edition Desmosedicis based street bikes on the GP 9 and 10 design.
yeah they announced this last summer i thought.
- real place
For $50 you can touch my
Re: Frameless ducs?
Reply #25 on:
February 24, 2010, 12:05:07 PM »
The article was estimating around 5 kg-that's pretty big, IMO.
gm2
Re: Frameless ducs?
Reply #26 on:
February 24, 2010, 12:17:39 PM »
engine
Turf
Awesome > Logic
Re: Frameless ducs?
Reply #27 on:
February 24, 2010, 05:37:59 PM »
It's fairly easy to see a V4 frameless SBK after the reign of the 1198.
justinrhenry
Super
weeeeee!!!
Re: Frameless ducs?
Reply #28 on:
February 24, 2010, 07:22:14 PM »
_____
2013 Honda CB1100D
2006 Honda ST1300
2003 Ducati Monster 620ie
Re: Frameless ducs?
Reply #29 on:
February 27, 2010, 05:38:11 AM »
Ducati could easily put a V4 high end bike marketed above the 1198 for around 30-40k and sell it well.
the original D16 did well, but at that price couldn't sustain sales. 30-40k less and it could be sustained in small numbers. the question is can Ducati make it for less than that.
