De-carbon pistons?
Started by Mr Earl, March 03, 2010, 03:27:12 PM
Without pictures I'd say you're fine, and yes you may have a mixture/temp difference between horizontal and vertical cylinders
Not sure how to quantify acceptable carbon buildup.
I use piston pins for spacers to hold the cylinders down.
Not all that helpful if you don't have 4 of 'em layin' around.  :P
Mr Earl
Here's a couple of pics:
Speeddog, I could cut some aluminum pipe sections to fit...
Leo Vince CF slip-ons, '01 SS900 fully adjustable Showa forks w/ST2 springs, rebuilt S4 shock w/Ohlins spring, 748 dog bone, Swatt clip-ons above the triple, Sargent seat, Duplicolor-Dark seat cowl, Rizoma grips, Techlusion TFI, SBK front fender, Evoluzione slave, BMC sport air filter, 14-tooth sprocket, Desmotimes caseguard, S2R side panels, Pantah belt covers, fake CRG LS mirrors, extra black zip-ties, right grip control imprint on tank, de-cannistered, Ducati Meccanica Bologna key ring
Quote from: Mr Earl on March 04, 2010, 06:31:03 PM
I'd leave it alone and use some chemical carbon cleaner as suggested earlier
~SNIP~
Yeah, that'd be fine.
Or even PVC pipe.
Doesn't need to be super bulletproof, just keep the cylinders down good and snug to the cases.
I use the piston pins 'cause they were laying around and the right diameter and length.
You could notch the ends so they're not sitting on the 'ring' that the head seals against.
scott_araujo
Quote from: ducpainter on March 05, 2010, 01:56:51 AM
+1.
