stalling when rolling on the throttle (carbed 900)?
Started by junior varsity, March 04, 2010, 10:20:33 AM
its going to have to wait an hour or so before I can tinker again (i'd like things to cool down a smidge before I cook a hand on the motor), the wife is deadset on a pizza pie for dinner.
Quote from: ato memphis on March 04, 2010, 02:45:08 PM
good thing I'm eating steak right now or I'd be jealous. ;D
Through a bit of seafoam in the tank to see if that could cure some bad gas... Got out there a bit this morning, revs fine for quite a long time, up and down the range, feeling good. Engine temp got to over 80c and things were going good for awhile (I had a fan blowing across it so it wouldn't get much hotter), but then a few minutes later, as I cracked the throttle open it was having trouble running and backfired a lot, all the way up to 5k or so. shortly after that I couldn't get it to rev up any further and it would die as I tried.
64duc
 Could also be worn needles causing fouled plugs. Pull a spark plug and look at the color.  Brown or tan = good  Black = bad
94 M900, 64 Diana 250
greenmonster
#22
QuoteWhile it was idling, i was checking all my lights and discovered I had forgotten to plug in the front brake switch. no big deal. Plugged it in, went to rev again, and in doing so, it sputtered as I got to about 3k and now it'll die when i try to rev it past there.
Check wiring around steering head.
Isolation often wears through, causing misfire, sudden death etc.
Does the fault occur on sidestand & just revving?
M900 -97
MTS 1100s  -07
on rearstand, happens after bike has been running for 10min or more... Once its gotten good and warm.
Could be fuel starvation rather than flooding I believe. Cory at the shop asked me to see if I had a leak in the intake tract.  Gonna look into that.
Punx Clever
Do you smell gas in the exhaust?  Plugs fouled/fouling?  If no, then starvation.
2008 S2R 1000 - Archangel
Played a little more today. Seems like it is starved for fuel, rather than flooding as I had originally thought - I'm not sure why I smelled gas the first time, perhaps it was my own? (bad joke.)
From my research, it looks like common problems come from heat/age with both the fuel lines and fuel pump. I'm going to try swapping 'em to see if that's the issue.
svr
any updates here?  i'm in the middle of changing fuel lines, filter, going to a manual petcock and just rebuild my fuel pump so i wanna keep up with how yours is going.
steven
waitin' on fuel pump to test (it has shipped, should be here any day now)
alibaba
Don't know much about these modern bikes, but on my old Brit Iron, this problem was symptomatic of 2 things.  A condenser breaking down under heat - which is obviated on these technological marvels  - or  -  a clogged vent in the gas filler cap.  (Too much wax.)  Now, I don't know if this makes any sense with a fuel pump but suspect an unvented tank might lead to fuel starvation.  Vent hose crimped someplace?
