900 Stuck in gear
Started by Monsterlover, March 06, 2010, 10:38:57 AM
There's probably enough damage to be either. :-X
Indeed.
At the least this thing needs a piston and probably a cylinder.  Possibly a head or at the least maybe valves.
Possible the head's ok as well though.
On the front, not sure.  It might all be fine there.
I can't understand why it would have been running lean.  Green top injectors are the same from the 750ie to the 900ie, and I got the right computer for the 900. . .
[bang] [bang] [bang] [bang] [bang] [bang] [bang]
Quote from: Monsterlover on March 07, 2010, 12:42:55 PM
Indeed.
Open airbox?
Nope.
Running the snorkels even.
Dunno...
It was undoubtedly lean.
You're sure it was a 900SS ecu? I remember there were some ecu issues when you did the swap.
One had the wrong pinout and the bike would crank but not fire the coils.
I got the correct ecu that fixed that.
How many miles on that engine?
Hmmm...
Squashed sparkplug
Piece of ring on drainplug magnet
Crank won't do a full turn
Trans won't shift
Aluminum shrapnel inside shift drum
I'm betting either a catastrophic failure of either the piston or rod.
Could have dropped the head off of a valve.
Usually a piston that burns through due to a lean condition will result in a drastic loss of power and an epic smokescreen.
mileage is unknown, but the po said it was like 6k.  I think it sat for a year or two.  I just put new belts and oil in it and let er rip.
Just wanted to update.
I borrowed a bore scope from the shop and went fishing down the plug holes.
Front cyl looks fine.
The rear cylinder is missing the piston.
All of it.
It's been pulverized into tiny bits.
Im even more sure than ever that this bike hates me [laugh]
Ddan
You really are awesome.     ;D
Ducati Monster Forum at
www.ducatimonsterforum.org
Too bad we can't get the bike's carcass to dallas for me tinker with.
Didn't I pm you asking if you wanted a shot at it?
Maybe that was someone else?
Anyhow, deal king scored a complete 900ie off eBay for 775 shipped from FL
this time I'm going to make sure it's not running lean.
Maybe some dyno time with a pc3 or something.
After it's running it will probably be for sale.
Remember...
It hates me.
;D
You did. Sigh. Perhaps it won't hate me! Must bother wifely unit some more.
Quote from: Monsterlover on March 30, 2010, 06:11:41 PM
Remember...
It hates me.
;D
It wants to be a 750 again. [evil]
It may hate me, but it doesn't hate me that much
;D
