Has anyone experienced this Toyota problem?
Started by superjohn, March 08, 2010, 03:33:39 PM
swampduc
Quote from: ROBsS4R on March 09, 2010, 01:01:33 PM
This is one of the many reasons why I drive a Manual =)
+1, haven't owned a car with an auto transmission in 13 years.
Respeta mi autoridad!
cyrus buelton
How do you operate a manual style system?
I've always been on automatic.
1999 M750 (joint ownership)
2004 S4r (mineeee)
victor441
#62
Quote from: ducatiz on March 08, 2010, 04:51:06 PM
It's the "won't go into neutral" part that really gets me.
The Prius doesn't have a neutral, reverse,  or even a conventional transmission, it uses planetary gears connected to the engine and the two motor/generators and the interaction of the parts is computer controlled, functionally it is like a CVT...FWIW there is a good page on this with an  interactive simulation at http://eahart.com/prius/psd/
ROBsS4R
So the drivers wasn't a dump ass ???
I watched the news interview tonight and he said he didn't
try to put it in neutral since he thought it might go in reverse... WTF
victor441
#64
Quote from: ROBsS4R on March 09, 2010, 08:47:13 PM
who knows?  he might well be, but the Prius "shifter" is really a multi-position switch so it is plausible that if the computers were wigging out it might be ignored...FWIW reverse on the Prius is handled by running one of the electric motors in reverse rotation rather than with gears
Kopfjäger
Can you reach up and turn the key off on these models?
victor441
#66
Quote from: kopfjäger on March 09, 2010, 09:04:17 PM
no conventional key on a Prius (and maybe some other models??), just an on/off button and a smart key you keep in your pocket or in the dash...from what I've read the off button needs to be held down for three seconds (an eternity in an emergency) when the car is moving and this doesn't happen in a panic situation, most people don't know this and understandably jab at it instead
Kopfjäger
Quote from: victor441 on March 09, 2010, 09:09:18 PM
no conventional key on a Prius (and maybe some other models??), just an on/off button and a smart key you keep in your pocket or in the dash...from what I've read the off button needs to be held down for three seconds when the car is moving and this doesn't happen in a panic situation, most people don't know this and understandably jab at it instead
Those pesky keys have always been a problem.
Quote from: victor441 on March 09, 2010, 09:00:25 PM
seems to me the system should be designed so shifting into neutral while moving is permitted as a failsafe.
even shifting to reverse on this car wouldn't hurt -- an unenergized DC motor going in reverse won't hurt it at all.
derby
and yet this guy had time (and was calm enough) to grab his phone, push four buttons, and talk on the phone while speeding down the highway at 90mph+ for 20 minutes.
-- derby
'07 Suz GSX-R750
cyrus buelton
#70
Does a Prius have a NaviComputer so it can calculate the jump into hyperspace?
2004 S4r (mineeee)
Quote from: derby on March 10, 2010, 04:04:02 AM
well, his name is Michael Schumacher..
have any of these incidents happened anywhere but NY and CA?
Quote from: ducatiz on March 10, 2010, 01:06:21 PM
Considering the number of things that have only been found to cause cancer in rats in Cali when the rats were made to ingest the substance...
I doubt it.
