Diesel mechanics on the board? Howie?
Started by herm, March 10, 2010, 01:55:38 PM
Bun-bun
Quote from: herm (not herb) on March 11, 2010, 02:39:39 AM
ne
is that because you dont have a diesel? or because it uses direct rail injection? my truck does not actually have glow plugs either....uses some kind of injectors....but its hard to refer to them as anything but glow plugs.
No, it's a diesel. It uses a heated wire grid in the intake plenum instead of glowplugs.
I think you're confusing glowplugs and injectors.
Glowplugs preheat the incoming fuel charge when the engine is cold, assisting in the combustion process. Think of them as sparkplugs.
Injectors spray the fuel into the cylinders under pressure.
Quote from: Bun-bun on March 11, 2010, 04:27:31 AM
<snip>
My 50 year old tractor has a small element in the intake that fuel drips onto and theoretically vaporizes making start up easier much like your wire grid.
I hope your system works better than that old Massey's.   [laugh]
Quote from: Bun-bun on March 10, 2010, 06:37:23 PM
Be glad you got the life out of them that you did. Neighbor had to replace theirs at 3800 (Yes, hundred) miles after buying their new powersmoke in '07. Had to replace them again this year at 67xxx miles.
I haven't had any problems with glowplugs in my '97 Dodge Cummins at all.
'cause it ain't got none!
I concur with the 97 Dodge Cummins. Sell the Ford and get a Dodge. Plus there is way more room under the hood with the inline six design. The newer Dodges have twice as many valves and you can get a compression release with them. [thumbsup]
herm
Quote from: D Paoli on March 11, 2010, 05:24:23 AM
well,....
IF i was going to sell my truck, probably would not buy another one so big, even if it meant getting rid of my trailer. so wouldnt need the diesel. but i will drive it into the ground, or the poor house, whichever comes first.
herm
Bun-bun
Quote from: ducpainter on March 11, 2010, 04:36:28 AM
The Cummins uses battery voltage to heat the wires, just like a space heater, and heats the incoming charge of air. It works fine as long as you have adequate charge in your batteries.
That old Massey sounds like an explosion waiting to happen.
And I'm with Herm. I'll probably die before it does, but even so, when I die, bury me in my Dodge.
Quote from: Bun-bun on March 11, 2010, 06:52:38 PM
Sure-just give me the keys  ;)
What could go wrong? ;D
rgramjet
Quick threadjack.
Duramax, Powerstroke or Cummins, which one and why?
Im looking at a 2500HD.  Love the quiet powerplant as opposed to the charter boat-like Powerstrokes that I've been around....
thx for the jack!
-Sofadriver
Quote from: rgramjet on March 12, 2010, 06:23:27 PM
Quick threadjack.
thx for the jack!
The Cummins...
in anything but a Dodge. ;)
Why...?
A diesel should be an inline engine.
I'd argue Cummins makes a better diesel, though I've never actually spec'ed anything out.
Quote from: ducpainter on March 12, 2010, 06:29:07 PM
The Cummins...
Why...?
So not the wonderful GM ones made from the Olds 350s back in the early 80's?  [laugh]
rgramjet
-Sofadriver
