Project 2v SBK 4/1/10 update
Started by TAftonomos, March 12, 2010, 02:51:26 PM
duccarlos
Did you buy the 749R from anyone in Atlanta? I've only met one person with that bike.
TAftonomos
Quote from: Triple J on March 17, 2010, 11:45:29 AM
Dang...a 999R even.  :o
Well, I think you're crazy...a 999R is a bad machine! Personally I'd pick up a newer style Supersport frame and pimp that out. Good luck though...I'll follow it for sure.  [thumbsup]
Be sure to get before and after weights on the project. It'll be interesting to see how much slower you made it.  ;)  ;D
The idea is to use a kick ass chassis, which the 999r (any 999 w/27mm offset) is.  Just happened on this bike, so thats what I'm using.  A SS chassis would be going the wrong direction for what I want.  This is the "easy" way.
Hell, I make the 999 slow just by getting on it.  Don't need 150whp for a track toy, and no this bike won't be covered up with fairings either...
Do you have a weight goal?
(yes, for the bike)
1KDS
Quote from: Triple J on March 17, 2010, 11:36:32 AM
...or a Supersport frame. Seems it would be easier and cheaper.
SS frames are junk, 999 frames are superb, I don't think he's going for easy and cheap either.
Every bike I've ever owned.
1KDS
Quote from: 1KDS on March 17, 2010, 02:05:57 PM
I'd disagree about the SS frames...
1KDS
compared to a 999 or in general?
Quote from: 1KDS on March 17, 2010, 02:24:00 PM
Both...
The 999 chassis is not all that different from a 748-9**. I own one (996) and the things are brutal to get turned.
The SS on the other hand, which I've also owned, was easy to turn and reasonably stable at speed.
I'm not discounting the superiority of the SBK chassis at all, just that the SS is far from crap and both have their strong points for different riders.
TAftonomos
MUST do the 27mm offset and flip the eccentric around on the 999.  1 line on the forks showing, rear axle back near the limit, and the ride height up there....she will turn :)
Stock they are very stable, but you really need to muscle them around.  Dropping the triples and raising the height will help a bunch...but nothing feels like that new offset and eccentric change.  You can change just the eccentric without doing the new triples...if you dare.  I didn't like it at all setup like that.
CA-Cycleworks tells me a FCR'd 1000ds motor will make 100+hp to the tire.  Unless I mis-understood him that was with stock heads as well!
I'd like to say 300lbs is my goal, but BST's arn't in my budget, and neither is a Ti frame.  I think I can hit 350 fairly easily.  I've also been thinking about a single rotor/caliper, as mentioned above.  I suppose if the bike isn't heavy, that ought to work just fine?!?
1KDS
the R has an aluminum subframe doesn't it? That should help
TAftonomos
All the mono bikes do :)  Like Stew said, it'll get a "trimming" :)
749R > 999R.
Its not as bad as if he'd taken the 749R frame. That'd be real shame.
Quote from: TAftonomos on March 17, 2010, 02:42:52 PM
no i think with that's with the MBP testarossa heads
Those were 900's bored for 95mm pistons (964cc...err "966" Monsters and SSs)
http://www.ca-cycleworks.com/shop/heads/heads.html
TAftonomos
#44
All the frames are the same on the 999 bikes (OEM).  There isn't one that is better, or one that has better geometry.  The 749 does have an eccentric in the triple, which is seperate from the headstock (kinda a double eccentric) which allows you to change the triple offset and the steering angle. All the other 999's (save the dark) can adjust the steering head angle, but to get the magic geometry you need to purchase an aftermarket triple with different offset.
The 100hp to the tire was on stock cams, stock heads w/FCR's.
You can spend the money on MBP heads with the factory fuel injection to get 100hp on the 1000ds motor
You can spend the money on MBP heads with FCR's on a 900 to get 100hp.
You can get 120hp w/fcr's, headwork and big bore on a 1000ds  [thumbsup]
A real shame?  Comeon now, you're not one of those elitist subscribers to the daily church-o-ducati's scriptures....are you? [laugh]  I bought the 999r cause the motor is worth more for parting, which is what is helping fund this project.  There was/is an equally nice 749r, that was the first choice...but I found the 999r
