February 06, 2025, 05:53:01 AM *
Pages: 1 [2]   Go Down
Author Topic: Evoluzione slave cylinder  (Read 3592 times)
Goat_Herder
« Reply #15 on: March 24, 2010, 11:17:05 AM »
when I went from 620 to S2R1K, I thought my left hand was going to fall off.  But after a week, I slowly got used to the heavier clutch pull.  But every now and then, slow traffic would drain my hand strengh.  I am some what dissapointed that you didn't get that much out of the Evoluzione slave.  I was seriously considering adding that and talked to my local dealer about it just last week.
Goat Herder (Tony)
« Reply #16 on: March 24, 2010, 04:19:37 PM »
+1. If you are giving it some real gas, I find it much better to just preload the shift lever, release throttle pressure, it clicks into the next gear nicely, and then on the gas again. A fluid motion.
 i hear preloading it is bad. once you do it a few times, it'll become automatic, if you just let of the throttle a bit and crack it back quickly, you'll realize when you can knock it in, and you wont need to preload.
the same thing applies for clutchless down shifting. though i wouldnt recommend doing it until you know how clutchless upshifting works, otherwise its the same thing, you just need to remember to get back on the gas enough to keep the rear from chriping.
loves ze desmodromics.
« Reply #17 on: March 25, 2010, 03:26:03 AM »
i just meant, get toe on lever, i don't begin yanking on it then.
along the same lines, you can do this in a manual transmission car.
Pages: 1 [2]   Go Up
