Lawn mower question
Started by NAKID, May 31, 2008, 10:55:41 PM
OT_Ducati
99 M750, 94 900sscr, 75 xs650 street tracker
WTH is that piece of shit...
OT_Ducati
Eastman Industries has taken the lawn mower to a new level (literally). The Hover Mower is designed to hover slightly above the ground on a cushion of air, making it more maneuverable, extremely light, easy to propel and able to reach previously inaccessible places like extreme inclines, wet grounds, and tight, difficult to get at places.
2stroke, so its s'posta burn oil http://www.thegreenhead.com/cool-stuff/2005/05/hovermower-by-eastman-industries.php
So it's light and maneuverable but loud as hell and smokes...
herm
Quote from: msincredible on June 01, 2008, 11:28:57 AM
When I had a lawn, I used to have this kind of mower...very low maintenance. 8)
major PITA to sharpen though....... :P
OT_Ducati
Quote from: herm on June 01, 2008, 07:52:55 PM
The newer ones are supposed to stay sharp at least 5-8 years...at that frequency I would just pay someone else to do it.
How is that even possible? Are they made of tungsten?
Quote from: NAKID on June 01, 2008, 08:07:00 PM
I don't have one of these (apartment, no lawn), but seen them recommended
http://www.peoplepoweredmachines.com/brill/brill_razorcut38.htm
55Spy
WHen it hovers over the grass and never contact it theres not much abuse to the blades.
BOT
the tipping for sure, just happened to have the exhaust port open this time is my guess
OwnyTony
When it is over filled with oil or tipped, oil can come out of either the carbs (rather the air filter that is attached to the carb assembly) or the muffler.  Just know this from first hand experience.  dont forget to check your oil level.
OwnyTony
Quote from: OT_Ducati on June 01, 2008, 07:58:57 PM
need more power?
This is one of the most stupid mods ever.  My regular lawnmower as well as any other gas mower can do (chop up watermelons and shrubs) what that nos powered motor could do.  Now if it was able to pull you across the yard at 20 mph while at the same time spinning the blades fast enough so that the grass is properly cut the first pass, then i would be impressed.  Nothing special about it or rather usefully functional about it.
