Colored sprocket carrier nuts
Started by uclabiker06, March 27, 2010, 03:15:25 PM
uclabiker06
#15
 " I'm confused... So what size are they on the S4Rs?"
I don't know
2006 S2R
2009 Smart
Metric bolts and nuts are described by the size of the threads.
AFAIK, *all* nuts and bolts are, with the possible exception of Whitworth fasteners.
The thread is 10mm.
The hex is 15mm.
99% sure all S*R are covered by that.
Might be good to confirm that those aluminum nuts can be torqued to the spec... [coffee]
DucHead
uclabiker06
Pro bolts,  specify no more than 44Nm or 33 ft/lbs.  Anyone know the torque value for these nuts?  I think manual calls for 11Nm but not sure.
2006 S2R
2009 Smart
hcomp
#20
I would not use aluminum nuts on the hub not even 7075-T6.....Titanium, Stainless, and Alloy Steel. We stock all the sizes for the hub. You don't have to buy from us, but the size is M10-1.25, but if you do, you get a 10% DMF discount!
Http://www.Ballerbolts.com
にã,,かかã,ã,‰ãšã€ç§ã®è»Šã¯æœ¬å½"に速ã,,ドラã,¤ãƒ–、私は女性のç"Ÿæ®–器のã,ˆã†ãªãƒã,¤ã,¯ã«ä¹—ã,‹
