New Zard Exhaust
Started by ctrain, March 29, 2010, 02:59:11 PM
scott_araujo
If 'm not mistaken, the exhaust to header gasket is a crushable single use thing.  Sometimes you get lucky and can reuse it, sometimes not.  Also, don't tighten down the bolts until everything else is in place and tightened.  If you have to loosen and tighten, same problem happens since it's already been crushed.  Cheap to get new ones, sometimes a pain to put them in.
Scott
DucatiTorrey
before you fix this, did you get video [evil]
  - real place
ctrain
Quote from: DucatiTorrey on April 01, 2010, 06:10:48 AM
I havent fixed it yet... guess ill be filming tonight. :) ;D
Bikes I've jumped and/or crashed:
84 Kawasaki KDX 80 - Bike i learned to ride on when I was young(er)
84 Kawasaki KDX 200 - First naked bike. crashed so frequently the plastics wouldnt stay on.
99 KTM 620 - If you could even get the thing kick started in the first place...
02 Yamaha Zuma - not a motorcycle but still crashed and jumped it way too many times.
04 Harley Road King Classic - Awesome story behind this
06 Ducati S2R 1000 - neither.... yet.
corey
Okay okay, we are talking about the gasket between the MidPipe and the Header Pipe.
I reused mine. Turned them inside out, the worked just fine.
I also slathered them in Permatex Exhaust & Tailpipe Sealant, per recommendation from some other folks.
ctrain
There isnt a leak between the header pipe and the midpipe. i believe the leak is between the header pipe and the engine block.
scott_araujo
Quote from: ctrain on April 01, 2010, 08:49:39 AM
And this area gets HOT, around 1200F or so.  RTV sealant will fail.  There are some thermosetting putties you can get but a fresh crush washer is best.
Scott
ctrain
Well I spent a few hours today putting the new crush gasket on.... and although it sounds better than it used to, it still sounds like it is leaking. I dont feel air like I used to but it still sounds like it is leaking.
[bang] [bang] [bang] [bang] [bang] [bang]
Any other ideas as to what it could be?
corey
might be good advice... heat = expansion... expansion = shit sealing up ;D
WhiteStripe
When i installed my Arrows something that helped me was to actually measure how far they should seat in.  In other words, looking into the female pipe if its 2" in to be full seated, throw a small piece of electrical or ducttape on the male pipe at 2.25".  That way you know if they are all the way in.
I found it hard to tell just by eye, and noticed along the way that i needed to go 1/4" more than i thought.
Not sure if this makes sense (or maybe just super obvious), but helped me get the fittament perfect and no leaks.  I reused the crush - literally just left them up in there.
Also, i assume you are using some kind of sealant on the non-header joints.  I used Permatex Copper RTV.  I just pulled my exhaust back apart and was please to see that 2k miles later the sealant was still intact everywhere (left header pipes on so did not check that).  Would recommend gooping that in there as well.
Not sure if this is helpful, but good luck.  You will get it sorted.
2006 S2R 1000, Arrow CF exhaust, FatDuc 02, CF open cc with stock pp
Autostrada Pilot
Any update ctrain?
BTW, let me know if you want to go ride (now that I have a bike again), this weekend is going to be gorgeous!
2003 Monster 620 Dark - Sold
1999 Monster 900 City - Sold
