February 06, 2025, 04:23:24 AM *
News: Please Help
Author Topic: HID lens  (Read 1757 times)
« on: April 18, 2010, 07:23:09 PM »
Not sure where to put this... since i bought that HID kit.
I was wondering what kind of lens i should get, shape? The question just becomes what kind. I have a few lens at home and playing around its seems like a plano converging lens...or hell, any kind of converging lens with a focal length of about 2-4 inches works best on my flash light, though sinc ei dont have the HID bulb with me, i wont know for sure how its suppose to work...
Autostrada Pilot
« Reply #1 on: April 19, 2010, 06:49:45 AM »
Wasn't TAft playing around with different lenses (and making his own, I think)?
2003 Monster 620 Dark - Sold
1999 Monster 900 City - Sold
TAftonomos
is without a monster :(
« Reply #2 on: April 19, 2010, 10:20:48 AM »
I did, I have waytogo
Lexan, + cut it out in a perfect circle, heat it up, and let it sink down till you get the shape you want.  Took me about 15 tries to get it right though!
« Reply #3 on: April 19, 2010, 10:39:44 AM »
screw that! 15 tries thats alot of time and money!  i can just buy something like it for $4-5 bucks, i just dont know what shape i want, or what kind of focal length im looking for...
TAftonomos
« Reply #4 on: April 19, 2010, 02:04:24 PM »
I looked plenty of places, didn't see anything I liked so I made it myself.  It wasn't that much, but it was more than 4-5$ per piece of lexan I used.
« Reply #5 on: April 19, 2010, 04:33:20 PM »
i found a lens shop that sells various glass, pyrex, plastic, acryllic, etc lenses from 20mm up to 75mm over 20 different shapes sizes etc. various focal lengths too.
djrashonal
« Reply #6 on: April 21, 2010, 06:25:49 PM »
you still gonna make your soda can reflector for the cutoff?
01 SSSSSSS4 - Sold
'09 Triumph Bonneville
S2R800 dark - searching for
Düb Lüv
ASE master internet mechanic
« Reply #7 on: April 21, 2010, 06:31:32 PM »
pffff! i don't know how you did it. i bought a heat gun and couldn't get the lexan to bend really, so i just cut a flat piece and stuck it in the bucket. this is how mine turned out.
Building, building, building
TAftonomos
« Reply #8 on: April 21, 2010, 06:45:55 PM »
Try your powdercoating oven, my house oven worked for me.
Düb Lüv
« Reply #9 on: April 21, 2010, 06:53:55 PM »
how did you set it up to get it sink?
« Reply #10 on: April 21, 2010, 08:03:42 PM »
wrong person.  Wink
this is how i plan on doing it.
Ditch the reflector....
make a small 60mm circle with 8 pieces of 1/8" steel wire, this is going to be the housing. install the lens in front, and drill 2 holes to rivet it, or perhaps use some type of high temp glue, not sure what temp the HID would give off...so im not sure about mounting it yet.
Then using one of the steel wire cages, weld a little bracket and rivet an aluminum soda can as a shield for the cutoff.
The point: Okay, this is where im going to get flammed for being "book smart" and not a real tech guy cause im studying to be an engineer.
Anyway, the point is, if i use a converging lens, i can clean up a lot of glare. The only issue is, i dont have enough lenses to play with to figure out the right curvature, focal length, and etc.
TAftonomos
« Reply #11 on: April 22, 2010, 03:19:52 AM »
Crap, lol.  Had me pretty confused for a sec there....  waytogo
Any household oven will get hot enough to heat form lexan.  I think I started at 275, but used 300-315 in the end to get it hotter faster.
« Last Edit: April 22, 2010, 03:21:28 AM by TAftonomos » Logged
« Reply #12 on: April 22, 2010, 08:20:49 AM »
i can get you to 715 in about 10 seconds.  Grin Hows that sound.  Grin
Taft, how wide is your lens? and how far is your bulb from it?
im looking at a 55mm lens wit ha 45mm focal length. seems like the best fit with spread.
« Last Edit: April 22, 2010, 10:11:48 AM by He Man » Logged
