Bitubo Steering Damper
Started by He Man, May 09, 2010, 11:34:48 AM
muskrat
and here's mine.  hope the weather holds tomorrow so I can test it.  this too is my first damper.  the hardley never needed one  ;D  Thanks to BellissiMoto for a great deal and fast shipping  [thumbsup]
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
muskrat
should I powder coat the brackets black?
2015 MTS 1200
09 Electra Glide
if u can get them hard anodized id go that route.
for me. its to expensive, im going to polish it, and solar rain that shit!
muskrat
#18
This damper rocks!  What a difference, best money spent so far.
2015 MTS 1200
09 Electra Glide
♣ McKraut ♣
Quote from: muskrat on May 19, 2010, 09:02:41 AM
it looked really killer in person, too... i would love to have one (especially seeing what crappy roads we have here in dallas), but i don't see it happening for a while.
-  Dallas, TX
BellissiMoto
Quote from: ♣ McKraut ♣ on May 25, 2010, 11:21:44 AM
Why not?
If money is an issue and your short a few bucks I'm sure we can help you out.
Stinson
Could this damper be installed while having handle bar risers installed?  It appears that the damper is attached to the ingnition cover and I'm worried that the risers may make this application void.  Would I have to get a cutom bracket made?  Thanks.
muskrat
GET IT NOW!!!!!!!!!!
2015 MTS 1200
09 Electra Glide
BellissiMoto
Quote from: Stinson on July 06, 2010, 11:24:14 AM
It's hard for me to say exactly whats necessary without seeing your bike and being able to play around with it all first hand, but one of our customers who has risers simply flipped the bracket that goes from the top of the handlebar mount upside down and it works perfectly.
Whether your solution will be that easy, or require a little more modification I can't say for sure.
desmoworks
To use these dampers with riser setups you need new spacers and mounting bolts to the ignition housing that are longer by the same amount of the new riser. This way all the mounting points, heights, etc... remain the same and it is still a direct bolt on. We've had several people do this who have risers or triples such as what SpeedyMoto offers.
Anthony Creek
Pro Italia Online || mota-lab
BellissiMoto
This is the Bitubo Damper mounted on the Hypermotard EVO SP.
The EVO SP comes with bar risers, but to make it work with the Bitubo damper, you only have to flip the top mounting bracket upside down as shown:
for reference, here is the Bitubo damper kit mounted to a standard Hyper
