Rear Brake Locks Up
Started by ejw24, May 24, 2010, 06:16:09 AM
RAT900
Quote from: ejw24 on June 06, 2010, 06:00:28 AM
ok I'll try putting more play into the pedal. A new rear caliper was the first thing I put on, would hate to have to spend another $200 for another one.
Thanks all for the advice
If you have the standard issue Brembo rear 2 piston caliper you can get brandy new one for under 100 bucks with the pads....a new master is even less than that
ejw24
Quote from: RAT900 on June 06, 2010, 09:36:59 AM
really, where?  Dealer charged me $200 for caliper w/ pads & $100 for the master cylinder...
I'm having a failure to thrive...
Quote from: ejw24 on June 06, 2010, 02:12:39 PM
http://yoyodyneti.com/
Yoyodyne even has a choice of colors ;D  When ordering it is a good idea to call and speak to Fred to make sure you are getting the right part.
RAT900
Fred at YoYo is still a great source
Lately I have used Aldrin of Rapid Moto Parts...he has good hooks into real-made-in-Italy Brembo supplies, EVR Bling, NCR stuff etc etc
He set me up with a pair of Sil-NCR Titanium cans new for 500 bucks
He has an ePay Store but prefers to go direct, you'll get better prices direct..
Good guy, great prices and no junk or mystery parts .....here is some of his stuff at this link
http://stores.ebay.com/RAPID-MOTO-PARTS__W0QQ_sidZ41820690QQ_trksidZp4634Q2ec0Q2em14?_trksid=p4634.c0.m14.l1513&_pgn=1
ejw24
Thanks for the sources everyone.  Will see what I can figure out, it's a damn frustrating problem!!
redial
just wondering -
it sounds like this locks up when you are not touching the brake? ( re: freeway at 80)
as in, it does not happen when you rearbrake and it just wont release?
ejw24
Quote from: redial on June 07, 2010, 11:02:52 AM
just wondering -
Correct, it just starts to tighten up gradually until it's like you are stepping on the brake 100%.  Weirdest thing I've ever experienced.  I did several test rides (20 - 30 miles each) on it before I was on the freeway this weekend, all of them had no problems.  Then rode  for almost 100 miles before it happened on the way home.
Quote from: ejw24 on June 07, 2010, 11:33:49 AM
so as your pads heat up they heat the fluid which expands and then closes the brakes.
overflow tube plugged?
errazor
For a Ultra propper bleed you might consider to loosen the caliper and line and hold it above the master when you bleed it to be sure that no air is caught in the line.
76 SUZUKI GT 100,  88 YAMAHA TDR 250,  07 DUCATI S2R 1000.
ejw24
Quote from: Raux on June 07, 2010, 11:49:26 AM
Yup, something causes the fluid to heat/expand.  But only at the caliper, the front of the hose & master cylinder is cool.  Line is no where near the exhaust & it's not like I used the brake too much to cause heating (when it happened Saturday I hadn't used the rear brake in at least 10miles)
Quote from: RAT900 on June 06, 2010, 09:19:55 PM
<threadjack>  So where is Aldrin these days?
Aldrin is indeed a good guy.
RAT900
Quote from: howie on June 07, 2010, 01:10:47 PM
Aldrin is a great guy,,,he is working down in Kentucky now, has the wife with him there....misses NY like crazy and wants to come back.  He is building up his own business at the same time he is working down there
He is doing some great deals by me for the odds and ends I need...I just picked up a pair of mint silver Narrow Band calipers off a 999 w/500 miles on them for 350.
G
