April 30, 2024, 11:06:47 PM
Can you paint over JB Weld?
Topic: Can you paint over JB Weld? (Read 13150 times)
May 25, 2010, 01:03:15 PM »
Tried a search on the interweb, i get hits on JB Weld will adhere to paint, but what about the other way around?
I got a hole in my left cover that got patched with JB Weld. Not sure if i can just go ahead and remove it, clean both sides. and just go ahead and paint it. Or if i should remove the JB weld, and weld it shut. id weld it myself, but i dont have any gas.
battlecry
On a silver black phantom bike...
Re: Can you paint over JB Weld?
May 25, 2010, 01:27:18 PM »
Wash it well, He Man. Some epoxies leak a waxy substance called amine blush as they cure. Not certain that JB Weld does, but it prevents many paints from curing well. Can be washed with soap and water a few days after the epoxy curing process is done.
rgramjet
May 25, 2010, 01:48:01 PM »
Yes. Will it stick? I dont know.
-Sofadriver
herm
May 25, 2010, 03:34:06 PM »
Quote from: rgramjet on May 25, 2010, 01:48:01 PM
it will stick for long enough...
May 25, 2010, 03:37:41 PM »
sand it...
it will stick.
