February 06, 2025, 06:58:12 AM *
News: Please Help
Pages: 1 [2]   Go Down
Author Topic: Ohlins suspension kits for S4Rt (2008)  (Read 5613 times)
hackers2r
« Reply #15 on: May 27, 2010, 03:22:28 AM »
To clarify, as I am an Ohlins dealer, the only place to get the OEM Ohlins products is from Ducati dealers.  And to be more specific, those forks you mentioned are upwards of $5k.
devimau
« Reply #16 on: May 31, 2010, 09:58:00 AM »
I have looked everywhere. Does OHLINS make any after market kits for the S4Rt? I was hoping to upgrade her suspension. Looking for fork cartridge kits (30mm or 25mm) as well as a rear shock. Am I out of luck?
I have an ohlins shock from an 08 s4rs that I can sell you for $400 already revalved for your type of riding.
If you need a different spring is extra (I might have some used ones).
If interested I can sell you ohlins front but also I can revalve your showis for $250 and they will work much better than an stock 25 or 30mm cartridge.
gecko
« Reply #17 on: June 01, 2010, 12:08:41 AM »
Hi devimau. Woud appreciate a PM with more details as to your OHLINS shock and forks. I live in Malaysia, and I wont be able to revalve my forks in the USA.
I rather get the kits so that I can assemble or install them here.
Thanks!
devimau
« Reply #18 on: June 01, 2010, 04:38:48 PM »
ok, tomorrow when I get to the shop I'll take some pics and pm you.
I live/work in Frazier Park California and we usually get suspensions from all over the world, Australia, Canada, Europe so living outside US is not a problem, I'm saying in my opinion revalved showas are way better than stock ohlins, but whatever road you take is fine with me.
« Reply #19 on: June 01, 2010, 06:25:11 PM »
what valve kits are u using?
devimau
« Reply #20 on: June 02, 2010, 10:27:23 AM »
is that for me?
« Reply #21 on: June 02, 2010, 02:07:40 PM »
Yes it is. Just wondering what valves do you use that are better than the 20mm ones. Were talking about the stock S4Rs ohlins right?
devimau
« Reply #22 on: June 02, 2010, 06:12:23 PM »
well, you have different options when you want to upgrade your suspension.
1st you can re valve your own components
2nd you can buy better components
3rd you can re valve the better components you bought
that's the key, when you buy better components they are not suited for your specific type of riding, so if you re valve your own components for the type of rider you are and the type of riding you do you are going to have way better results and save more money.
now, if you buy better components and then re valve them to suit your riding style then you'll have the best results but sometimes is not necessary.
let's say that I weight 140 and I'm an experienced racer and I buy a 1098s and go racing, the first thing I do is respring them but then I want to upgrade the valving, if you call ohllins they'll tell you to buy the superbike kit p/n xxxxx.
on the other hand my friend weights 240, has the same year and model bike and is just starting to go to the canyons and wants to upgrade his suspension, we respring his components but he wants more, we call ohllins and they'll recomend us to buy the same superbike kit p/n xxxxx.
now, do you get the idea, there's no way that what works for my under racing conditions will work for a guy 100 pound heavier than my and riding in a different environment with a different rider's skills.
that's why it's important to understand how the suspension works and modify what's needed to meet anybody's needs.
for example we just did a 1098 with showas for a racer for big willow and the bike was cruising doing 1:27 no sweat, so is there a need for somebody to spend 3k on front ohlins because he's just going to start doing track days?
immo no, I'd rather re valve the for $300 and spend the other $2700 on tyres.
sorry for the speech he man, we usually use our own valving, I might use different piston depending on the application but the shim stack configuration is a custom job for each rider to meet his needs.
gecko
« Reply #23 on: June 02, 2010, 08:54:19 PM »
Devimau. Thanks for the email. Unfortunately, I feel that its is slightly to pricey to pay 600 bucks for a second hand shock (with new spring) and then after factoring the postage, the whole thing is going to cost too much. Appreciate your input and your help though...
« Reply #24 on: June 02, 2010, 09:59:56 PM »
Ah, i see, I have a 999 Showa installed on my Monster with the proper spring and always wonder if i should pony up for a used Ohlins, or try and revalve the thing to get some better performance out of it. But i dont know how far revalving can get me to a used ohlins.
devimau
« Reply #25 on: June 03, 2010, 05:43:35 AM »
no problem, I think is a bargain for an ohlins shock already revalved for you @ $400, also the rear spring is $75 so it would be $475 and not $600.
the postage from california to malasya for the shock only would be $100.
HalvorV
« Reply #26 on: June 07, 2010, 09:31:23 AM »
I`m also looking to upgrade the suspension on my 2007 S4Rt.
This is what I have discovered so far:
Rear shock - The Öhlins DU333, as ugly as they can possibly get with it`s golden colour and external pre-load and N2 tank.
                  But a good quality shock that bolts on, no sweat.
                  Penske - 8983 or 8987 good quality (maybe just as good as the Öhlins) and visually a much better match
                  with my gray bike. Ti spring is a nice touch.
                  Matris - M05R kind of a dark horse,  I have not been able to find much feedback regarding installation on a
                  Monster.
All of the above are custom built to suit bike, rider and riding style.
Front forks - Re-valve and respring, a good fix for the Showa. Relatively cheap and "good enough" for street riding?
                  Öhlin SBK / ST forks, need to machine/change triple clamp. But high quality forks BUT again the f*****g
                  gold colour.
                  Matris F05R Cartridge, should be a good fit and high quality but limited info from users.
                  Marzocchi USD 43 Not quite sure of the quality of these forks, guessing OK but  little or no feedback
                  from Ducati users.
I have not decided what I`m going to use on my bike. Leaning towards a Penske (rear) matris (front) set up.
Any input/experience will be very much appreciated!!
« Last Edit: June 07, 2010, 09:33:53 AM by HalvorV » Logged
2010 Monster 796 ABS
2007 Monster S4Rt
2006 Vespa GTS250ie ABS
Pages: 1 [2]   Go Up
