February 06, 2025, 02:58:07 PM *
Pages: 1 ... 3 4 [5] 6 7   Go Down
Author Topic: SS rebuild  (Read 23795 times)
« Reply #60 on: June 13, 2010, 03:05:47 PM »
Gotcha. . .
done many a car audio install in my day.
that being said, there's no way the stock cables are 6 gauge.  Id guess 10 at best.  At least on my bike. . .
I have a bunch of leftover power and ground wire (8 gage and 4 gage) and the 8's are slightly bigger than the stock wire (insulation OD)
Even if they were the same gage I'd bet that my wire would pass more juice as they're braided copper and very flexible whereas the stock wire is pretty stiff.
You really can't go by insulation od.
Just sayin'
The best kind of whore is a
« Reply #61 on: June 13, 2010, 03:29:43 PM »
I know, I know.
I'll peal back the insulation and measure it
Will report back Grin
DesmoDiva
« Reply #62 on: June 13, 2010, 03:41:50 PM »
 applause applause bow down bow down bacon bacon
B wants to know which model of KTM that is??   Grin
'01 ST4 Yellow
'02 ST4s Yellow
« Reply #63 on: June 13, 2010, 03:53:44 PM »
Prototype super duke never released to the public Grin
DesmoDiva
« Reply #64 on: June 13, 2010, 03:58:25 PM »
You must have got a killer deal on it!!
 Kiss
'01 ST4 Yellow
'02 ST4s Yellow
« Reply #65 on: June 13, 2010, 04:07:03 PM »
Last year yeah.
After destroying the last motor and finishing this rebuild I probably can't afford to get rid of it laughingdp
« Reply #66 on: June 13, 2010, 04:40:32 PM »
All the stock cables I've played with were 6ga...  Maybe someone did a switch-er-oo on you.
« Reply #67 on: June 14, 2010, 12:14:12 AM »
I never changed them.
I think he's assuming the od reflects 'normal' insulation thickness.
TJR178
2004 Monster S4R, 2010 HD FLHRC
« Reply #68 on: June 14, 2010, 02:51:05 AM »
Sweet man!  I can't believe it looks like that after seeing it sprawled across the floor only a few weeks ago.
 applause
« Reply #69 on: June 14, 2010, 03:40:06 AM »
When are we doing yours?
Evil
« Reply #70 on: June 14, 2010, 10:14:02 AM »
No. . .
the 8 gage I have is only slightly larger than the wire on the SS (od) so that leads me to believe that the wire on the duc is 8 or smaller.
Like I said, I'm gonna measure it.
♣ McKraut ♣
touched by his noodly appendage
« Reply #71 on: June 14, 2010, 11:03:25 AM »
No. . .
what would be an optimal ground cable gauge for upgrade purposes?  would it be different for the liquid cooled bikes?  i've thought about doing this on suggestions from others (in re: easier starting of the engine), but wasn't sure what exactly i would be looking for in terms of gauge etc.
btw really nice work on the rebuild   waytogo
-  Dallas, TX
« Reply #72 on: June 14, 2010, 11:12:37 AM »
Thanks!
Should be no difference for a liquid cooled bike.  If you have 10 gage now, or 8, you could step up one size larger (8 or 6)
« Reply #73 on: June 14, 2010, 01:51:19 PM »
From my research, stock cables are 6ga so an upgrade would be to go to 4ga.
« Reply #74 on: June 14, 2010, 02:11:54 PM »
Well, here's what I found.
The 8awg wire I have is Phoenix Gold wire and it's labeled as 8 awg.
I cut back some insulation on the ground and starter cables and they measure .190"
As does my 8awg wire.
According to all the charts I just found with google, .190 wire diameter puts it between 5 and 4 awg.
My wire has thicker insulation on it.  My theory was that the bike's wire was also 8awg or smaller ( I was thinking 10. . .cloudy memory) which proved to be correct.
However, that's using my wire as "8awg" reference.
In reality it seems that it's really larger than 8.
Not sure what else to say except I guess I could throw on a piece of 4awg I have but in reality that's probably more like 2 laughingdp
Pages: 1 ... 3 4 [5] 6 7   Go Up
