I think it could be... You can buy the kit pre-tuned for the termi system or buy it with the PC6 untuned for a slightly lower price...
So, you could buy the kit, and then have it tuned to fit your bike's own setup.... That is what I plan on doing...
I think the reason they list the DP ECU is because that's what comes with the termi system... If no DP ECU, buy the kit with the non-tuned PC5 and have it done yourself
Here is a link to another board which has the numbers for this kit...
http://www.ducati.ms/forums/showthread.php?s=3efa404a37680647eb1013cf1dc7171b&t=88258They went from 75HP to 81HP... A pretty good increase... And I think with a better, open exhaust the power might be higher.... I am curious what I would dyno at with my H-Competition underseat exhaust.... The termi system only added 1 HP according to the dyno....
Excellent info, thanks.
I wonder which version of the H-comp will turn the best numbers
. Whenever this becomes available I'll most likely be buying the kit. Will have it dyno tuned and post the results for sure. Probably won't be until next season though.
Wow, I'm really impressed with the numbers and the chart results he got from the kit. It's funny that the termi gained a net 1hp after custom tuning...
I think I'm sold on the wasp kit.
