August 19, 2024, 05:15:14 AM
CAM
What did you do today?
109
110
111
112
201
Topic: What did you do today? (Read 320052 times)
zooom
Re: What did you do today?
Reply #1635 on:
October 21, 2011, 03:38:09 AM »
Quote from: tocino on October 20, 2011, 04:45:04 PM
Bought a shovelhead.
musta been a cheap project bike....
2010 KTM 990 SM-T
Autohag
Reply #1636 on:
October 21, 2011, 04:41:20 AM »
What year? Whatcha gonna do with it? Resto?
Omnipotent Potentate
Personal Pretext
Reply #1637 on:
October 21, 2011, 04:44:00 AM »
Quote from: Autohag on October 21, 2011, 04:41:20 AM
Stick a long piece of wood in the end and dig a hole
The Mad King Pepe'
Reply #1638 on:
October 21, 2011, 04:47:53 AM »
So are you selling the Guzzi??
Chain jumped off the rear sprocket on the way to work, fun times!
Looks like I'll be chainging the un-holy trifecta.
TitanMonsterS4R
Reply #1639 on:
October 21, 2011, 04:55:29 AM »
Changed the oil. Then took the scenic route to work....
zooom
Reply #1640 on:
October 21, 2011, 05:03:06 AM »
Quote from: The Mad King Pepe' on October 21, 2011, 04:47:53 AM
it didn't punch a hole in the case or damage anything did it?
2010 KTM 990 SM-T
The Mad King Pepe'
Reply #1641 on:
October 21, 2011, 05:23:16 AM »
Quote from: zooom on October 21, 2011, 05:03:06 AM
Cases are OK, just a broken tooth on the rear sprocket. Happened as I down shifted from 5
th
to 2
nd
when I was on the ramp off the parkway.
Chain must be on its last legs, I had checked and lubed it some time last week and it appeared fine so I didn't tension it. At this point I'll chainge both sprockets and the chain...
zooom
Reply #1642 on:
October 21, 2011, 05:40:23 AM »
Quote from: The Mad King Pepe' on October 21, 2011, 05:23:16 AM
th
to 2
nd
last chain and sprocket set I got, I ordered from Rick at MotoCD.com ....he chatted with me about how I was riding and conditions and advised me on which chain would be best from both a usage and a $$$ perspective....and I think it cost me about $210 shipped...
damn, this reminds me...I have to get my chain tool back from a MAD meber I loaned it to.
2010 KTM 990 SM-T
696DCRider
Reply #1643 on:
October 21, 2011, 06:29:11 AM »
The chain thread brings up a question that I have had in the past. When I was at the shop getting a helicoil kit installed recently, the shop guy told me that my chain is a bit worn and probably will need to go next season. My question is how does one know when it's truly done for so that you don't have an instance like Massimo just had?
Personal Pretext
Reply #1644 on:
October 21, 2011, 06:32:46 AM »
A variety of things can indicate.
Frozen links/Kinks
Stiff sections
Sings of uneven wear - usually due to kinks or stiff sections.
Having to adjust the tension on it a lot more than you had in the past
What else fellas?
zooom
Reply #1645 on:
October 21, 2011, 06:46:23 AM »
Quote from: Sad Panda on October 21, 2011, 06:32:46 AM
Frozen links/Kinks
Stiff sections
What else fellas?
reaching the end of your adjustability
teeth on rear sprocket looking like curved sawteeth instead of being symmetrically straight up
2010 KTM 990 SM-T
The Mad King Pepe'
Reply #1646 on:
October 21, 2011, 06:50:18 AM »
Quote from: zooom on October 21, 2011, 06:46:23 AM
Not mine, just an example of a sprocket way past its prime.
tocino
Reply #1647 on:
October 21, 2011, 06:50:57 AM »
1982 (the shovel FXRs were only made for 2 years before they switched to Evo engines)
Going to clean it up and ride it!
First thing off were the wild-west leather saddle bags (had to do that first thing this morning they were bothering me so much).
Then will be the tassels on the levers - wtf are those things for? When I was riding home they kept catching my eye and I was like "what's that?!? oh, them silly tassels", and then the back-rest thing (with ubiquitous born-to-ride eagle logo).
I'll swap the drag pipes for the stock setup that came with the bike (after powder coating them black)
Next will be new bars (the stock ones are weird, position felt like I was offering a tray of snacks to the lord and lady of the manor).
Then paint the tank (it's just primer).
That'll be it, except for some carb tuning which it needs and a bit of cleaning / polishing.
It's only got 20K miles on it and has not been f*&%d with, which is unusual for these bikes. People usually lowered them (thus ruining the Eric Buell-designed handling characteristics), or chopped them up or stole the motors for other projects.
It's heavy bastard, that's for sure.
696DCRider
Reply #1648 on:
October 21, 2011, 06:52:57 AM »
Thanks. So in other words, I should probably be eyeing my chain regularly for these types of signs. I probably need to be lubing my chain more frequently anyway.
Frozen links/Kinks
Stiff sections
What else fellas?
The Mad King Pepe'
Reply #1649 on:
October 21, 2011, 06:58:45 AM »
Quote from: 696DCRider on October 21, 2011, 06:52:57 AM
And after lubing the chain, take it for a light ride and then RE-CHECK the tension. I think that's what got me.
109
110
111
112
201
