Electric Impact Wrench?
Started by DrDesmo, June 04, 2008, 07:07:58 AM
For the S*R bikes, an impact gun makes it a *lot* easier to get the rear wheel nut and rear sprocket hub nut off.
It *can* be done by yourself using a breaker bar, but it ain't easy.
All Monsters, the flywheel nut is very very difficult by hand, I've done it.
Few folks will need to do it, but if you have to get the primary gear off the crank, I don't think you can do it with hand tools.
I've never tried to do the gear puller by hand, as I've had an impact gun available.
3/4" drive breaker bar isn't cheap, and it's far less versatile than an impact gun.
DrDesmo
Quote from: Monstermash on June 04, 2008, 09:03:44 PM
No need for an impact on a bike.
There's no need for offset box wrenches, T-Handle drivers, cam wheel holders, flexible socket extensions, or any of the other tools people own.  I want one because it makes jobs easier, like removing the rear wheel, flywheel, etc.  The one time I use it (ie, when I replace my chain and sprockets) it's paid for itself vs. going to the dealer.
I buy tools because they make life easier, not because they're an absolute necessity.  And FYI, it's not just for my bike.
My question wasn't "hey, what does Tom think about me owning one??" it was "what's a good one to get"  [cheeky]
-Adam
'95 916
'12 800XC
Magnus
I have to agree with Q on this. No need for an impact on a bike.
ever replace your clutch basket?
'02 MS4 Black Fog
Monstermash
Adam,
I could see if you did ALL your own wrenching on your bikes but clearly thats not that case. I can't ever see you removing the flywheel, clutch basket, etc. The problem with an impact is that too many people don't really know how to use it. It sounds simple enough and it is for removing stuff but I've seen way to many people break off bolt heads or stripping threads when reinstalling. And we all know just how tough the factory Ducati bolts are so thet'll never happen right?  [roll]
The kind of general maintenance you'll most likely be doing really doesn't require one. The only time an impact is needed is on the heavy duty jobs which unless your going to lend it to Seacoast, you'll never need it.  [laugh]
clubhousemotorsports
From the service end of things I can tell you that some customers equate impact guns with poor service. I have no idea where this came from but the former owner of the shop I worked at was talking about banning the use of impact guns for wheel changes due to negative customer reactions. In the end it comes down to educating people that when used Properly an impact tool can be a much better choice, It is all in the application.
Now back to the subject at hand, I would look for a gun that will have about 250ftlbs  in reverse to get the rear wheel nuts and loctited flywheel,clutch,primary,front sprocket nuts off.
I almost never install with an impact gun due to the fact I prefer to torque things.
In some applications the torque wrench is all about speed which = money to a mechanic/shop.
Others it is because the impacting action will help to break a fastener loose and reduce the chance of damage to the parts.
DrDesmo
#20
Quote from: Monstermash on June 05, 2008, 07:22:16 AM
Adam,
Tom,
Thanks for your concern.  Seacoast did the Dyno tune on my Ape because - shockingly - I don't have one in my garage.   And the Swingarm recall because - again - shockingly, i'm not an Aprilia dealer so I can't get one sent to me directly.
A few things:
1.) I'm not using it to reinstall things.  I have several torque wrenches of different sizes and ranges for that.
2.) If I was reinstalling things, I'd use torque sticks like I do when working on my Volvo ... But then again, I only use Torque sticks and an impact gun when reinstalling lug nuts, nothing else.  I'm not using it to install bodywork or clutch retaining bolts here  :P
3.) I am, actually, planning on doing my own wrenching on my bike save for valve services, which I may or may not tackle over the winter.
4.) I am, actually, looking at putting a lighter flywheel on my bike.
5.) I'm looking at getting a tire changer, too.  Feel free to give me some uninvited smart-ass comment about why I don't need that, too.
6.) Thanks for assuming I'm an idiot.  I appreciate that, Tom.
Adam
'95 916
'12 800XC
ScottieDucati
#21
You shouldn't ever "need" an easy-out either... you shouldn't ever "need" to drill out a bolt that you stripped... you shouldn't ever "need" an impact gun to take rotor bolts off (like the ones on DesmoTull's SP that have clearly never, ever been removed from the bike, and snapped TWO 5mm allen 3/8" bits... while being *very careful with a breaker bar and applying slow and steady torque, mind you.)....
Oh and god forbid you swap your own wheels on your car or do maintenance on things other than your bike(s)....
I agree, you don't *need* anything but some good sockets, allens, wrenches, etc... that said, we used an electric impact (cordless) at the track for years, which made tire changes on 748/996's a breeze when the weather decided to act up last minute.
An impact gun is something that when used properly (as has been stated previously) will make your life easier, jobs go quicker, and... could very well *prevent* damage to other tools, or bolts, as they are specifically designed to remove high-torque applications or bolts that have seized... the "impact" jars the seized or torqued bolt while applying torque, something you simply cannot do with hand tools.
I'm sure none of us on the board have ever dealt with a bolt that wouldn't come undone on our Ducati's before...  [bang]
Adam,
White hott 848... under the knife :D
Monstermash
Quote from: DrDesmosedici on June 05, 2008, 07:38:59 AM
Tom,
A few things:
Adam
Dude,
You need to chill. Notice the emoticon at the end of the statement? You know this one >>>>>> [laugh]
I find it funny. I agree with Q and you jump down my throat. I notice you didn't say anything in response to him. Whats up with that?
I just suggested that an impact wrench was a bad idea. I certainly understand the need for some tools that you rarely use but thats one tool I will never own. As I mentioned before I have seen way too many bolts stripped because of an impact gun. I'm not saying it was the users fault although most times it is. The torque settings are not the greatest on those things and sometimes, well, things happen.
If you plan on using it on your car, why are you posting it in tech on the DMF??
And Scottie,
As you make this statement I will agree that the uses you listed are acceptable on a certain level. Having on at the track for quick tire and wheel changes could be invaluable. Also the rotor bolts can be a real pain in the ass. When I did Jewcati's last year on his one year old bike I broke an allen socket as well, forget trying to do it on an older bike that have never been removed before.  [bang]  That being said, I was using a cheap tool. When I grabbed my Snap-on 5mm allen socket I had no problems at all.
IMO it's better to use hand tools whenever possible. They give you more control, and although my not be easier, they definately are safer for both you and the bike.
A few have mentioned removing the rear wheel bolt and the countershaft sprocket. I have done both of those two operations many times without the use of an impact gun. Is it a little harder? Yes, but it's not that hard.
DrDesmo
Quote from: Monstermash on June 05, 2008, 08:50:36 AM
You need to chill.
Oh, I'm perfectly chilled right now my friend - that being said, you have no idea what you're talking about in this instance, and your "unless you lend it to Seacoast" comment is what provoked me to respond.  Sorry if I called you out on making uninformed statements about what I do - or don't do - with my bike.
Quote
Q Asked a question - you left a paragraph about how unnecessary they are, Implied I don't do any work on my bike, etc.  And you still don't get why I want one, not that it matters a lick.
QuoteIf you plan on using it on your car, why are you posting it in tech on the DMF??
Huh?  I'm using it for a few different things:
- Flywheel replacement when I put a Nichols on
- Rear wheel removal
- When I upgrade my clutch basket
- When I replace my chain & sprockets on the SV
If you'd like to continue this conversation through a PM or phone call, please do.  This thread really isn't the place for it.
-Adam
'95 916
'12 800XC
DrDesmo
Quote from: Qfactor on June 04, 2008, 02:11:04 PM
I've used the makita, great tool.
not sure I would need one for bike stuff tho...
what do you need it for?
Q
Q -
- Tightening bodywork fasteners on the VFR
- Reinstalling those tiny little allens in the inside of the gas cap on the S4R
- Working on watches and fine jewelry
- Tightening down my bar end mirrors on the S4R
- Tightening any bolt that has a well nut on the other side
- Installing hard drives in my desktop computer
- Tightening those little bolts that hold your clutch springs in, at max torque setting
- Belt tensioners on the 996
- Back massager
[laugh]
Adam
'95 916
'12 800XC
dlearl476
To each his own
Had you used a heat gun (another power tool) to loosen the red locktite the factory uses when installing the rotor, chances are you would have been fine with the cheapie.  IMO, it's more important to know what you're doing than what tool you use to do it.  I would NEVER use an impact wrench to INSTALL anything, other than the lug nuts on my cars and even then, I only hand start the nuts, give a quick "blat" to snug them down, then torque them with a torque wrench.
Quote
Once again, to each his own.  If you want to spend 30 minutes getting a stubborn counter-shaft sprocket off with a collection of sockets, cheater bars, heat and wedges, have at it. It takes about 3 seconds with an impact wrench.  IMO, taking my forks OFF with a pneumatic ratchet takes at least 10 minutes off the job.  Time I can save for the important stuff, like ripping my fork seal, spilling fork oil all over my MC lift, and pinching my friggin finger getting my disc back into the caliper.   [thumbsup]
dlearl476
Quote from: DrDesmosedici on June 05, 2008, 04:44:27 AM
-Adam
Spoken like a true tool whore.  Bravo Sir.  [thumbsup]
DrDesmo
Quote from: dlearl476 on June 05, 2008, 09:18:46 AM
Hey! I resemble that remark  [laugh]
Adam
'95 916
'12 800XC
ScottieDucati
Tool. Whore.
Hmmmmmm... You resemble both at times!!!   [thumbsup]
Hahahahaha I couldn't resist.
You are amassing quite a garage-ma-jal however, good work :D
Quote from: DrDesmosedici on June 05, 2008, 09:21:16 AM
Adam
DrDesmo
Quote from: ScottieDucati on June 05, 2008, 09:32:39 AM
Tool. Whore.
Oh yeah? Well i'm rubba and you're GLUE ...  [laugh]
Adam
'95 916
'12 800XC
