February 12, 2025, 05:24:09 AM *
Pages: 1 [2]   Go Down
Author Topic: Metal tank on S4RS?  (Read 6986 times)
« Reply #15 on: April 04, 2011, 07:26:11 PM »
Bump for this, anyone ever confirm a 05 metal tank will fit?  I found one, but it's $$$ and I'd sure hate to have to try and re-sell it if it doesn't work out......
the main issue is the fuel pump i think. its shaped differently to accomodate the different heads. i have an 05 steel tank sitting on my shelf with a dent in it. as soon as i figure out how to pull that dent ill throw it on my bike...
Online Online
« Reply #16 on: April 04, 2011, 07:41:05 PM »
It will fit...trust me. You'd have no trouble selling it anyway.
The reason the S4RS has a different pump set up is as He Man says because of the 4V heads. The S4R isn't that different. The steel tank actually has more room in that area.
You'll need the bracket for the frame and the plastic bushings. I think the pin is the same.
You'll also need all the internals along with a cap holder/bung.
« Reply #17 on: April 04, 2011, 08:25:30 PM »
Dunno if I said it in that other thread, but....
The fuel line to go from the pump to the filter and from the filter to the output hardline *must* be submersible rated, SAE 30R10.
It's not the typical fuel injection rated line from the parts store, which is SAE 30R9.
30R9 hose *will* fail.
Be prepared to pay ~$30/ft for Gates 5/16" 30R10 hose.
It's sold in one foot lengths, you'll need two.
Or you can get the OEM hoses.
Online Online
« Reply #18 on: April 05, 2011, 03:00:04 AM »
You also need the two sections that go from the cap holder to the vent and drain tubes inside. They are slightly smaller than the pressure line.
Pages: 1 [2]   Go Up
