New Headlight
Started by supertjeduc, June 25, 2010, 06:03:24 AM
Düb Lüv
Quote from: supertjeduc on June 25, 2010, 06:03:24 AM
Found a headlight (no not a V Rod)
I think it cleans up the front end
you have a pm
Building, building, building
ab
Not sure if I like your  new head light.  hmmm
I just installed the HID Kit.  The stock was just horrible.  Huge difference   ;D
things i like about this headlight so far. for the 696/1100 it has the same amount of wiring. a parking light, low beam and a highbeam. it's not just a single hi/low beam. so wiring to my stock connector was easy. it's pretty light per se. and it's not too deep, i should be able to mount it pretty close to the triples.
TAftonomos
Quote from: ab on July 02, 2010, 09:03:46 PM
If you used the stock headlight, just want to say.
THANKS FOR BLINDING OTHER DRIVERS.
Putting a HID "kit" in a halogen housing just means you now throw so much glare over to oncoming drivers they can't see.  Just want you want....someone looking away from the road the closer you get.
Get a proper HID projector, and retrofit it inside your headlight.
Quote from: TAftonomos on July 03, 2010, 04:23:04 AM
I sort of agree with you.  Technically all you say is correct.  There are so many improper or poorly aimed over wattage bulbs out there headlights out there that it almost doesn't matter.
ab
#35
You got a point there.  You are correct.
But with me not being able to see at night with the stinking stock lights (even after cleaning the case and changing bulbs to higher volts), I had to try the HID kit and get it.   It is what it is for now.
Unfortunately, I will have to join the "There are so many improper or poorly aimed over wattage bulbs out there headlights out there"
I don't know about you but we ride a lot at night  and I need this and this is all i can afford to get at this time.   >:(
