May 14, 2024, 07:26:13 PM
M900 jetting advice
Topic: M900 jetting advice (Read 5621 times)
sur4die
Re: M900 jetting advice
Reply #15 on:
June 19, 2008, 11:37:08 AM »
so what drove me to futzing with my carbs in the first place has decided to rear its ugly face again, though not nearly as bad.
previously i had power delivery problems when cruising at higher speeds (higher loads) and higher engine speeds. scenarios like 80MPH in clean air (not drafting). if in this scenario i will periodically experience a brief loss of power either upon gentle throttle application or simply cruising. it used to feel like hitting a brick wall, now it's more of a hiccup.
i had thought that this was needle clip position related, and hence probably how i managed to break my fuel pump vacuum hose with the starter cable by removing my battery box to get at the slides.
does anyone have other ideas about what this could possibly be?
Reply #16 on:
June 19, 2008, 12:36:10 PM »
Perhaps your fuel pump is getting a bit marginal on delivery.
Is it the original?
sur4die
Reply #17 on:
June 20, 2008, 05:02:56 AM »
Quote from: Speeddog on June 19, 2008, 12:36:10 PM
Is it the original?
you know, that was my FIRST impression also. so i ordered the rebuild kit and installed. no dice.
so i thought maybe my tank is flaking rust into the system. so i ordered one of those tank sealer systems, flushed all the lines, the pump, and completely broke down the carbs, dipped them, and put it all back together. no dice.
somewhere along that journey i ripped open the fuel pump vacuum line and the last thing i did was fix that hose and i'm kinda back where i started... although not nearly as bad.
hey, at least it's rideable
sur4die
Reply #18 on:
June 22, 2008, 05:34:02 PM »
so after a day or so the bike began to have issues holding an idle. it would run on one cylinder and intermittently. the plugs looked a little too sooty so i decided that it was running too rich and changed out the main jet to the 145 that came in the factorypro kit.
so far the 145 is really making a big difference! there is definitely more power and everything seems to be behaving, for now. i only went for a short ride to lowes for holesaws, i'm building a reef tank, but throttle response was much crisper.
i'm going to have to get it out on the highway this week to see if this jet change solves my high speed cruising issues.
Hedgehog
Reply #19 on:
June 22, 2008, 07:27:43 PM »
Just a random comment here, on jetting. I got the Factory kit, and eventually wound up with good plug color with 130 mains, 70 starter, 40 pilot, 60/1.4 pilot air, y-2 needle jet, factory springs, 3 1/2 turns on idle screws, and needle is 2 from top. This is on my 94 900SS.
sur4die
Reply #20 on:
June 23, 2008, 04:50:03 AM »
Quote from: Hedgehog on June 22, 2008, 07:27:43 PM
for whatever reason the 900ss likes smaller jets than the m900. take a look at the example installs about half way down.
http://factorypro.com/Prod_Pages/prodd09.html
then look at the m900 page sample.
http://factorypro.com/Prod_Pages/prodd12.html
and the instructions that come with the kit give 2 more examples for the m900 and both recommended the 155 with an open airbox and high flow exhaust.
i guess my setup doesn't flow all that great after all. i have always known that straight pipes and pod filters weren't the best performers, no scavenging, but i guess i just didn't want to believe it.
sur4die
Reply #21 on:
June 24, 2008, 05:27:12 AM »
took it in to work this morning...
it started easily enough, but idled a little rough, intermittently dropping a cylinder. it was doing this before, but it would do this after it warmed up. now i'm intermittently dropping the one cylinder only when it is still a little colder.
so my best guess is that my idle was a little rich, and now is a little lean. i'm going to ride home and check plugs before i make any adjustments though.
oh, it is also definately running a little bit warmer than it has been. i'm also going to try and duplicate this observation on the return trip.
printman
Check out my a.....
Reply #22 on:
June 24, 2008, 01:50:22 PM »
Quote from: sur4die on June 23, 2008, 04:50:03 AM
I would agree with this
142.5 main 4th clip from top (richer) and a 40 pilot
I'll update this later at a convenient time Thank you for tuning in.....
sur4die
Reply #23 on:
June 25, 2008, 04:34:19 AM »
Quote from: printman on June 24, 2008, 01:50:22 PM
what's your setup (intake and exhaust) on this jetting Printman?
printman
Check out my a.....
Reply #24 on:
June 25, 2008, 05:40:41 PM »
open air box and stock exhaust
Would really die off at 9000, cause of the long intakes
FCR's have it running strong on top
sur4die
Reply #25 on:
June 26, 2008, 04:33:50 AM »
i really wish i had a tach...
meano_lover
Reply #26 on:
July 07, 2008, 03:25:04 PM »
this just helped me alot. thanks y'all.
'97 m900; stage 2 carbs, filter pods, remus carbon exhaust
sur4die
Reply #27 on:
July 07, 2008, 03:32:39 PM »
Quote from: meano_lover on July 07, 2008, 03:25:04 PM
i'm glad it helped someone... i couldn't quite get mine dialed in and i needed new tires mounted anyway, so i am having my local shop dyno tune it while it's in for the tires.
i'll definitely post the settings that come back on it though.
meano_lover
Reply #28 on:
July 07, 2008, 04:29:11 PM »
i'm in the middle of doing mine right now. i hope it all goes well...
