Started by DRKWNG, June 27, 2010, 08:24:17 AM
I don't profess to be any sort of mechanic, but I have a feeling this could be a contributing factor to why the Jag is not handling like it did prior to the accident.
I think you're onto something there.  :P
Might want to ogle the other side, see if buying a pair might be the ticket.
Quote from: Bick on August 08, 2016, 03:48:57 PM
Is this rear right? how did this happen?!  ???  :o
Quote from: Speeddog on August 08, 2016, 04:02:23 PM
Oh, this seems to be a 'before' pic:
You think there might have been a small break in it before like that, and being pulled off axis during impact put enough stress on there to finish the break?
Quote from: Bick on August 08, 2016, 05:10:54 PM
YES!!!
Rameses
I'm not 100% sold on there already being a small break there, as there's no visible surface rust on the outer portion of the break.
But there's definitely a good chance that the metal was already highly fatigued in that spot.
Looks like a serious design flaw.
Oldfisti
Quote from: Rameses on August 08, 2016, 05:48:39 PM
Yes that stress crack in the same spot is definitely suspect.
Bick's Jag is from Cali, his pic shows very little rust anywhere.
Even the cast iron disc isn't rusted much, those usually will nearly have fur in a wet/salty environment.
Inspect the crack, see if there's features like this:
I suspect it was at the least cracked partway through on the bottom, and the crash may have ripped it through to the window that the E-brake cable passes through.
Continued driving fatigued through the top.
That scenario correlates with Bick's description of it's driving behavior, IIRC.
Quote from: ducpainter on August 08, 2016, 06:14:56 PM
Did the shop do any pulling?
They did nothing on that corner yet.
Quote from: Speeddog on August 08, 2016, 06:27:50 PM
The car was only in CA for @ a year, but it was driven on snow in CO for the the years prior to that.
Thank you for the info.  Interesting.  I will look at the break when the parts come off.
Rameses
Quote from: Monsterlover on August 09, 2016, 05:51:13 PM
Bacon with a bonus
[puke]
Seriously, that made me feel a little nauseous when I realized the thing that looks like a nipple actually was a make the beast with two backsing nipple.  [laugh]
Quote from: Rameses on August 09, 2016, 07:56:36 PM
[puke]
[laugh]
