A monkey off my back (rewiring project)
Started by Drunken Monkey, July 06, 2010, 06:29:49 PM
Quote from: pompetta on July 08, 2010, 10:13:26 AM
What about the Pingel switches?  Spidey has five buttons on his left: horn, hi beam, left turn, right turn, and motogadget toggle.  I take it the first four (and start + run on the right housing) can't just be wired up to the existing harness?
On Spidey's bike:
Start button works as it's wired through a conventional relay.
Kill switch had to be wired through a latch relay (basically a relay that changes state in response to a momentary push button)
Turn signals were also wired through a latch relay (but aren't quite working right)
Horn was wired through a regular relay.
But latch relays are pretty finicky and I think Spidey's turn signals don't exactly work right. It's harder on his bike since I think the ECU controls the turn signals.
I was able to get my set-up working initially by using a self-canceling turn signal kit, and then wiring the push buttons normally.
Start button and horn went through a relay.
And no kill switch(!) or high-low beam control.
As for "ready to go" kits that plug directly into an existing harness... Someone is surely working on something like that (coughsworntosecrecycough)
DucHead
Thanks for the info DM.
I really wish that I would have chosen a more (personally) useful vocation.   :P
Quote from: pompetta on July 08, 2010, 02:15:05 PM
It's not like I'm an electrician, or an EE man. Junior High electronics class (circa 1982) FTW!
DucHead
Quote from: Drunken Monkey on July 08, 2010, 02:55:38 PM
OK, now you're just making me feel stupid.   >:(
;D
Some Dude
#19
Quote from: pompetta on July 08, 2010, 03:24:07 PM
;D
Whenever I feel Stupid Beer makes me smart again [drink] [drink] [drink]
Bike Info
99 m900s                                                Sbk forks
41mm FCR's
Dyna coils
944 hi comp pistons
heads ported and polished
larger valves
new valves and cams
aluminum fly wheel & clutch basket
[bacon]        [bacon]        [
It's true. Whenever I lacked the courage to start cutting wires, I drank  [drink]
DarkStaR
Quote from: Drunken Monkey on July 08, 2010, 11:52:06 AM
Interesting, I'm on it!
It's done! My saint of a wife gave me* enough time off this weekend to finish up the wiring (and in some cases re-wiring) as well as all the wrapping (and in some case, re-wrapping) and securing of the new harness.
(*okay, I took the kids to the zoo while she went off to watch the World Cup in exchange)
The low point was when all the wires decided to pop out of one of the connectors I was using so I had to re-figure out what went where and secure the whole mess again with hot glue (memo to self: don't re-use ancient connectors)
The high point was figuring out how to wire up two diodes to one of the push buttons so I could have flashing hazard lights.
I still need to find the old motogadget manual, as the newer ones have different colored wires for the speedo sensor (no speedo at the moment) and in general I need to spend some time shuffling around the components a bit for a cleaner installation.
Still, I rode the bike into work this morning and everything worked great  [thumbsup]
Photos to follow.
cool stuff. gonna be doing one of them there boxes at some point
Rob Hilding
 [popcorn]
Nice work -
One of these days I'll work on my projects (good thing these bikes don't depreciate ;))
Mojo S2R
i gots them thar brack and klootch masters, i like 'em lots.
DucHead
 [drool]  Damn dude, I'm lovin' your control switches!!   [beer]
Thanks  ;D
Now I just need to spend some time actually riding my bike, rather than tearing it apart  [roll]
Also a bath. It needs one.
