November 24, 2024, 04:50:07 AM
CAM
Craigslist and other deals
67
68
69
70
138
Topic: Craigslist and other deals (Read 305649 times)
tocino
Re: Craigslist and other deals
Reply #1005 on:
November 21, 2011, 07:58:57 AM »
Quote from: zooom on November 21, 2011, 06:12:51 AM
http://washingtondc.craigslist.org/nva/mcy/2712089033.html
this seems too good to be true...
Well, that price is between KBB trade-in and retail values and it *is* 16 years old, so not abnormally low. That said, still a great price for a great bike provided it is in excellent shape with low miles.
The Mad King Pepe'
Reply #1006 on:
November 21, 2011, 08:50:15 AM »
Quote from: tocino on November 21, 2011, 07:58:57 AM
I would be more concerned with the electrical wiring than the miles on a 16 year old
Italian
motorcycle... might give you more than a few
moments, followed by plenty of
zooom
Reply #1007 on:
December 01, 2011, 10:49:02 AM »
OOOOOooooooh Rogerrrrrrrrrr....
http://washingtondc.craigslist.org/doc/mcy/2730002670.html
cr500r very fast lots of parts larger gas tank sunpro chain and sprockets weisco piston full pro circuit exaust stealthy offroad 11oz flywheel weight tires are in good shape have extra brand new rear scott stearing stabilizer fmf stand
$1700
2010 KTM 990 SM-T
bikepilot
Reply #1008 on:
December 01, 2011, 02:02:20 PM »
I owned a couple of those and my dad had a third.
Lots
of low-mid power, no top/overrev, loads of vibration, pistons tend to fragment (but bottom ends are bulletproof and the wiseco in the linked bike should hold up ok, mine did), don't handle very well. I got better laptimes at budd's on my 125s and worked half as hard doing it I think, was faster still on a 250, but more work than the 125. The 500 was big fun in a straight line. The KX500 has a significantly better motor, but an even more archaic chassis. I think these things best suit large, lazy riders who can't be bothered shifting or nabbing the clutch. The 500 pulls so hard off the bottom you can start in any gear. I usually left the line in 3rd and didn't have to shift all the way to the first turn unless the start was really long. It pulled 4th gear starts just fine too
. They are also an absolute blast in the dunes, but the chassis doesn't soak up really hard landings like a modern(ish) bike so make sure to hit a good downslope.
If I lived near big dunes I'd have a KX500 motor stuffed in a stiff aluminum chassis.
On anything other than sand or loam it'll be hard to keep up with a current 450 in a straight line as the 450 hooks up better.
2009 XB12XT
2006 Monster 620 (wife's)
1997 TL1000S
1975 Kawasaki H1 Mach III
2000 XR650R (dez racer)
2003 KX100 (wife's)
rgramjet
Reply #1009 on:
December 01, 2011, 02:34:04 PM »
Quote from: zooom on December 01, 2011, 10:49:02 AM
$1700
That's a bad mofo right there. Timing is bad at the moment.....looking at a diesel F350 on Saturday! Priorities.
-Sofadriver
Reply #1010 on:
December 01, 2011, 09:42:57 PM »
Quote from: rgramjet on December 01, 2011, 02:34:04 PM
those new superduty's are just ridiculous
getting a crew cab dually with a long bed?
buy a ladder
rgramjet
Reply #1011 on:
December 02, 2011, 06:11:03 AM »
Yeahhhh, I don't have $60k+ to drop on a pickup.
I found a nice used 04 Lariat crew cab with the long bed and a cap. It had the egr delete and the other appropriate 6L issues dealt with.
The short bed is more to my liking .......haven't driven a long bed crew cab. The thing is a beast!
-Sofadriver
The Mad King Pepe'
Reply #1012 on:
December 02, 2011, 06:38:59 AM »
Quote from: rgramjet on December 02, 2011, 06:11:03 AM
Just saw a youtube video of one of these for sale: I wish they made an SUV based on it! With a smaller 3-4 liter turbo diesel engine for decent mileage, and about the size of the Ford Explorer. Wonder if an engine swap was possible...
Here's the vid:
Reply #1013 on:
December 02, 2011, 07:43:02 AM »
the 350 is just too damn big. If you need more than an F250, then you should be looking at something like a Unimog.
bikepilot
Reply #1014 on:
December 02, 2011, 12:58:53 PM »
Not really on the size, the 250-450 are all physically the same size and sit on roughly the same frame (except for dual rear wheels on the 450 and optional on the 350). Main difference between them is spring rates, final drive gearing and that sort of thing. You basically just pick the stiffness based on how much weight you wanna tow. My dad uses a 450 for pulling his toyhauler. I use a 250 for pulling my box trailer full of dirty bikes
They don't physically get any larger until you get into medium-duty trucks (F650+ in ford language).
Oh, and unimogs can hardly move themselves - you certainly wouldn't wanna tow a 20k lbs trailer over the rockies with one!
FWIW I'd be really hesitant about buying a 6.0L - just not a very efficient or reliable motor. I'd rather have the gas motor or the old 7.3L, either of which shouldn't cost any more than the 6.0L. The current PSD seems quite good, though it is still pretty new.
The duramax isn't bad and the 5.9 cummins is great (but comes wrapped in a not-so-great truck).
I'm pretty positive swapping a smaller motor into an F350-sized truck won't get you any more mpg. It 'll still take the same amount of energy to move that much weight and push that much wind. The big diesels are quite efficient in terms of hp/lbs of fuel. Also there are hardly any decent small diesels in the states to swap in. A small, modern, efficient diesel in a lighter and more aero truck could be cool, but honestly as good as modern DI gas motors are I think diesel makes less and less senses these days except for towing huge loads. Jeep put a little diesel in their little SUV. It didn't sell well, was sorta crapy and mpg didn't blow people away.
The V6 F150 is quite efficient and the ecoboost V6, which is similarly efficient, tows almost like a diesel. That's the direction I'll most likely head if I ever wear out the old 7.3 F250.
Here's dad's tow rig
It toted the (packed) toy hauler over some of Colorado's highest passes when we were out playing in Summer '10 with nary a wimper
Last Edit: December 02, 2011, 01:27:31 PM by bikepilot
2009 XB12XT
1997 TL1000S
2003 KX100 (wife's)
Reply #1015 on:
December 02, 2011, 01:00:32 PM »
Quote from: bikepilot on December 02, 2011, 12:58:53 PM
huh??
rgramjet
Reply #1016 on:
December 02, 2011, 01:19:59 PM »
There is a local contractor, "Rembrant Builders" that has a unimog in its fleet.....impressive machine! They must be making some serious $$s!
From what Ive read the only differences between the 250 and 350 SRW is 4 spring blocks vs 2 on the 250 and standard tire size 265 vs 235 on the 250.
The 7.3 is an undesputed workhorse! Again, from what Ive read, the 6L had some issues that were ironed out with a couple mods. Ive seen several for sale with "new" motors.
-Sofadriver
bikepilot
Reply #1017 on:
December 02, 2011, 01:34:50 PM »
A 2hp winch will move stuck things very slowly as well. For that matter so can I with a leverage multiplier. Neither it, me, nor a Unimog is any good at towing in a practical sense. If you wanna crawl up passes at 2mph a 'mog might be ok
If you wanna run something like the speed limit up a pass (or anywhere) a 'mog won't do it. No matter how cool you look, 80hp won't move a 20,000lbs trailer up a mountain at anything like a normal road speed.
The 6L's issues aren't all easily fixed with basic mods. For one, it hasn't got enough head bolts/studs to keep the cylinder heads firmly attached to the block. Now if you don't mod it and don't push it too hard and are a bit lucky it could last quite well -- it isn't a bad performer.
2009 XB12XT
1997 TL1000S
2003 KX100 (wife's)
Real Recognize Real
Reply #1018 on:
December 02, 2011, 05:07:51 PM »
With all this truck talk, I'm planning on purchasing a quad cab truck next year. I don't need a full size truck but since Ford won't sell the new 2012 Ranger in the States and Dodge discontinuing the Dakota, the compact truck market seems like slim pickings. Ideally, there would be a compact truck option with 3.0L diesel powerplant but I'm not holding my breath.
Don't argue with idiots. They'll drag you down to their level and beat you with experience.
Reply #1019 on:
December 02, 2011, 05:13:34 PM »
Quote from: gwjcat on December 02, 2011, 05:07:51 PM
fat chance. look for my "you're too stupid" thread. you'll see a hybrid small truck with fairy wings first.
67
68
69
70
138
