November 24, 2024, 04:25:38 AM *
Pages: 1 ... 22 23 [24] 25 26 ... 138   Go Down
Author Topic: Craigslist and other deals  (Read 305513 times)
The Mad King Pepe'
« Reply #345 on: March 04, 2011, 07:16:24 AM »
+100000000000000
FRAAAAAAAAAACK: Sweet Deal!
Lars D
« Reply #346 on: March 04, 2011, 03:40:15 PM »
Do tell...
+1
I have found multiple bikes in the area and when I am not working on a saturday I will simply go buy one.
Lars D
« Reply #347 on: March 04, 2011, 03:42:48 PM »
Also, please do not mention other bikes as I have had a hard enough time deciding.
Moderator
« Reply #348 on: March 05, 2011, 04:35:00 AM »
lol
 Evil
The Mad King Pepe'
« Reply #349 on: March 05, 2011, 05:22:44 AM »
D'oh, never mind. I just noticed they're W heads which have smaller valves..  Embarrassed
tocino
« Reply #350 on: March 05, 2011, 09:33:35 AM »
 waytogo
MadDuck
The anti-
« Reply #351 on: March 05, 2011, 12:49:28 PM »
No worries. Put FCR 41's on it and it'll run with the big valve engines no problem. Seriously. I did that with my old '98 and it's still running strong. However, the FCR with the V heads?, it did cross my mind a few times to that someday.  cheeky
Lars D
« Reply #352 on: March 05, 2011, 02:31:48 PM »
Has anyone just hogged out a set of heads to see what the performance improvement would be?
If so ,where did you have it done??
tocino
« Reply #353 on: March 05, 2011, 09:13:26 PM »
I believe the first thing you want to do (after FCRs) is clean up / open the exhaust ports and then run a slightly bigger pipe, sans the bad collector. The unobtanium spaghetti hears were the ticket.
The Mad King Pepe'
« Reply #354 on: March 06, 2011, 05:19:59 AM »
It really depends on what your final goal is and how much dinero you're ready to pour into it. For ultimate performance Chris Kelley recommends the testarossa head work by Guy Martin. If you go the whole 9 yards, the testarossa head work will cost you a good 3K.
But with split 41 FCRs on short manifolds and 95mm high compression pistons (966 cm3), once everything is properly setup, you should be in the 100+ HP neighborhood. That is pretty much the highest amount of power you can get from an old 900.
Buuut now that the new 800, 1000 and 1100 2V engines have come out it might not be worth it to dump all that money into the bike. Brad Black has a good comparison of the different engines on his site. Essentially, for an engine build from the ground up, it's better to start with a 1000 (or 1100), put in a big-bore high-comp kit and then move forward from there to get the most bang for your buck.
The most surprising of Brad's discoveries is that the stock headers aren't that bad. They flow pretty well, and the 'X' section helps get more power at higher RPMs vs two individual pipes.
Bigger is better, but only to a certain point. The bigger the pipes are, the slower the exhaust gas moves, and when it's too slow the heads will not fully empty themselves of exhaust gas, meaning that less fresh mixture will go in. Which is a bad, bad thing!
Me? I'm a cheap bastard! cheeky The less I can spend on an engine, the better. I'd like to get my hands on a 1000+ engine, possibly from a Hyper or an old Multi since the cases are already narrow for the SBK swingarm. But that would mean getting and tuning a TCIP box to run the engine off carbs. So a 900 might work out better for me.. but that's for another thread Wink
zooom
« Reply #355 on: March 06, 2011, 06:35:56 AM »
you can also talk to Donnie about taking W heads and putting the bigger tulip valves in after cleaning up the head and doing a 3 angle on it and some cams out of a newer FI head and you'll have still spent way less than the Testarosso heads and get a damn good bit of performance.
2010 KTM 990 SM-T
tocino
« Reply #356 on: March 06, 2011, 07:46:20 AM »
Did ya get one? Didja? Didja?
Lars D
« Reply #357 on: March 06, 2011, 09:37:39 AM »
I had to work yesterday and mor than likely the next 3 to 5 saturdays .
Quite a few SD's I have found are in PA and NJ and are mostly 08's.
The Mad King Pepe'
« Reply #358 on: March 08, 2011, 05:28:52 AM »
I hate not having my own garage! I would jump on this deal immediately! Angry
MadDuck
The anti-
« Reply #359 on: March 08, 2011, 08:35:06 AM »
That bike is way too hammered. If you got it really, really cheap then maybe.
Pages: 1 ... 22 23 [24] 25 26 ... 138   Go Up
