November 24, 2024, 06:02:34 AM *
Pages: 1 ... 43 44 [45] 46 47 ... 138   Go Down
Author Topic: Craigslist and other deals  (Read 305949 times)
zooom
« Reply #660 on: June 24, 2011, 06:48:21 AM »
I think this is calling Bikepilot's name!!!
http://washingtondc.craigslist.org/nva/mcy/2459461690.html
2010 KTM 990 SM-T
The Mad King Pepe'
« Reply #661 on: June 24, 2011, 07:04:13 AM »
I think you got it wrong, this is the right bike: 1998 CR500 converted to SuMo
zooom
« Reply #662 on: June 24, 2011, 09:57:07 AM »
yeah, but is that available for sale now and streetable?
2010 KTM 990 SM-T
Moderator
« Reply #663 on: June 24, 2011, 10:20:59 AM »
Streetable?  Doesn't matter.  Not like anyone could catch you on that thing.
The Mad King Pepe'
« Reply #664 on: June 24, 2011, 12:28:45 PM »
2009 KTM Duke 690 for 5999 at MFI
bikepilot
« Reply #665 on: June 24, 2011, 01:57:34 PM »
That 690 is really sweet, but I want this http://www.motorcyclefactoryinc.com/new_vehicle_detail.asp?sid=04391291X6K24K2011J2I35I24JPMQ2287R0&veh=179448&pov=2124644
2009 XB12XT
2006 Monster 620 (wife's)
1997 TL1000S
1975 Kawasaki H1 Mach III
2000 XR650R (dez racer)
2003 KX100 (wife's)
The Mad King Pepe'
« Reply #666 on: June 24, 2011, 02:06:17 PM »
UNACCEPTABLE! Angry
Unless you put a turbo on it! Evil
KTM SMR 990 TURBO PART TWO
bikepilot
« Reply #667 on: June 24, 2011, 02:09:52 PM »
A turbo would suit me fine  Evil maybe then it'd be able to hang with the MTS1200  Dolph
2009 XB12XT
1997 TL1000S
2003 KX100 (wife's)
Autohag
« Reply #668 on: June 24, 2011, 03:59:39 PM »
http://washingtondc.craigslist.org/nva/mcy/2460680552.html
Autohag
« Reply #669 on: June 24, 2011, 04:00:31 PM »
Or this: http://washingtondc.craigslist.org/mld/mcy/2448072679.html
Moderator
« Reply #670 on: June 24, 2011, 04:11:43 PM »
Who cares??!!  What happened at the storage room last night?
The Mad King Pepe'
« Reply #671 on: June 24, 2011, 05:44:58 PM »
+1 !!!
The Yamaha seems like crazy fun, but it will probably require an oil change a week (a la Aprilia SXR). The DRZ is much more interesting (decent HP and normal maintenance), I found a few local ones on supermotojunkie.com
bikepilot
« Reply #672 on: June 25, 2011, 06:50:33 AM »
DRZs are pretty slow unless you mod the heck out of them.  Not necessarily a problem, just don't expect too much.  I have fun on a 17hp DR250 sometimes so power isn't everthing, but DRZ's are only good for about 33hp in stock form and those 33hp don't even come on very quickly - heavy flywheel and sedate throttle response.  If you convert them to E model spec (FCR, exhaust, different base gasket for more compression etc) you can get around 38hp which isn't too bad in a light bike and throttle response improves dramatically.  Bomb it out with big bore, high compression, cam etc you can see in the mid 40s.  Folks have gotten even more hp from them, but it tends to get really expensive and reliability becomes questionable.
A sumo'd XR650R would be fun on the street I think.  Decent, though not insane power, rugged and reliable and the power it does make comes on really low and pulls hard.  Not unlike the power curve you get from an 1100 desmo.  Power is in the low 40s stock and you can sneak up on 50hp with mods, but that's about the cealing.  Fortunately they don't weight any more than a DRZ.  Kick start only and only available as a dirt bike though so work to be done to make it a sumo.
MFI had Husqvarna SM450s for, I think, $5k not long ago and that Duke 690 for $6k would make a heck of a good street motard.
The yamaha would make a great track toy.  A bit maintenance intensive for the street, but not horribly so.  Change oil every 800ish miles and it'd be good I'd think.  The valves in those hold up quite well.  Note though that it has a very close ratio 5spd gearbox so you'd need to run really tall gearing inorder to be able to go freeway speeds without revving its gutts out.  Also it vibrates a bit.
2009 XB12XT
1997 TL1000S
2003 KX100 (wife's)
Moderator
« Reply #673 on: June 25, 2011, 07:10:38 AM »
To bad they quit selling this thing here:
The Mad King Pepe'
« Reply #674 on: June 25, 2011, 03:43:18 PM »
<snip>
Here you go: this from super moto junkie.com
2007 DRZ400 Supermoto
2,372 miles as of 6-20-11, I'm still riding it some though so it may increase slightly
Located in the Lynchburg, VA area, zip code 24502
$4,500 firm, cash - not interested in trades right now of any type
Clean and clear Virginia title is in hand
The bike has:
-Ice Cube 455cc big bore kit
-FCR carb
-Hot Cams
-Full MRD/SSW exhaust with an APA slider/protector
-Stainless steel brake lines front and rear
-K&N Air Filter
-Rubber Killers
-Zeta Handguards
-LED tail light/fender eliminator
-Contiforce SM tires installed about 350 miles ago
-New battery as of 2-12-11
-1 (one) key (that's all it came with)
-A lot of stock parts listed and pictured below
Lots of photos with the post, and he also has all the stock parts. If I had the money and the disposition, I would have hit it yesterday.
Fact is I need to try one out first (hint, hint) AND I need to finish Project Bianca before I dive into something new.
Pages: 1 ... 43 44 [45] 46 47 ... 138   Go Up
