This is funny. I went through the same thing. I tried doing something about it.
A couple of months ago i placed a TomTom on the bike. All in all it turn out to be pretty much
useless in sunlight as the LCD got drowned out by stray light. Especially if you had on polarized sunglasses or if your visor was also polarized. I've long removed the device from the bike! A failed attempt that was.
I have yet to give up. I started work on a circuit based on the SiRF-Star GPS chipset. The circuit send pulses to your stock or third party speedometer such as the Motogadget or simple bicycle speedometer. In effect your speedometer will read these pulses just like it would your normal stock reed sensor. It will also allow you to tune the output frequency based on the OD of your wheels along with a constant multiplier for the number of reed sensors(1-5). Some bikes have more then one sensor pickup. The output will be just that of the stock sensor, either 2wire reed type or 3wire open-collector type, but based on GPS signal and whatever wheel size configuration the user programs for the third party speedometer is tuned to accept. Simple!
Cool thing about this, is I can pull such information as heading to name a few. Maybe i'll make my own speedometer display with integrated heading information.
The prototype circuit went for a test ride with me in the truck hooked up to a frequency counter. The frequency did lock on to my truck's ground speed. The Analog portion of the circuit is proven. Don't know when i'll finish the alpha unit to install on the bike. Just need time to layout the board and design a package for it.
Pros:
- One less wire on the bike. No need for the stock wheel sensor. Cruiser ppl will love it!
- Great for muddy environment such as dirt bikes and quads that don't come with any speed sensors.
Cons:
Not sure if i'll bring this to market. I'll have to see how the design function in real life application and what demands are for them. If you're interested in being a lab rat, let me know. I usually make 3-6 prototypes of anything i make.
