February 07, 2025, 01:13:05 AM
Please Help
Domino Throttle Control or G2 Ergonomics Tamer Throttle Tube
Topic: Domino Throttle Control or G2 Ergonomics Tamer Throttle Tube (Read 19920 times)
S2R 800 '07
Re: Domino Throttle Control or G2 Ergonomics Tamer Throttle Tube
Reply #30 on:
November 08, 2010, 12:13:21 PM »
Quote from: Heath on November 08, 2010, 11:45:53 AM
This is why I want to get the Electraeon.
I hardly ever get to 100% throttle
because it takes too much twisting to get there.
That issue must be solved
jchurch
Reply #31 on:
November 08, 2010, 03:16:15 PM »
hey guys question for anyone with the G2 Throttle Tamer installed.
Did you just adjust the throttle cable from top of throttle cable only as I have done
OR
did you adjust at the bottom near the throttle itself as well. I measured the 'freeplay' on mine currently at around 6-7mm however I ain't getting any 'jerkyness' I assumed this extra ''freeplay' was caused by the tamer/cam install to alleviate the original stock 'jerkyness' as described in the G2 video.
Just making sure I have mine setup in the best possible way.
Current Bike: 09 M1100
Previous Bike(s): 02 M900I.E
04 Aprilia RS125
S2R 800 '07
Reply #32 on:
November 08, 2010, 03:34:42 PM »
Quote from: jchurch on November 08, 2010, 03:16:15 PM
OR
I don't have a G2, but 6-7 mm sounds way too much.... Do you really mean you can twist the grip 6 - 7 mm without it resulting in anything? For me, the on/off throttle was gone when I reduced my freeplay to almost (ALMOST!) zero.
My adjustment was done down by the engine.
jchurch
Reply #33 on:
November 08, 2010, 03:47:07 PM »
Ok interesting.
I placed a piece of paper on grip and throttle assembly and measured the distance i could move before it revs. I got to around 6-7mm, interestingly enough I don't get the bite caused by what you would think would be much slack.
I will adjust mine down below then as I cannot adjust any further from the top as it will only allow so much.
04 Aprilia RS125
S2R 800 '07
Reply #34 on:
November 08, 2010, 03:53:40 PM »
I think the top adjuster is meant for minor adjustments, like when the wire stretches a little bit over time.
Screw the top adjuster all the way in before you adjust down by the engine. Then fine adjust on top.
jchurch
Reply #35 on:
November 08, 2010, 03:58:48 PM »
Ok no problems, I will give this a go tonight.
Thanks for your help.
04 Aprilia RS125
BK_856er
2007 M695; 2004 749s
Reply #36 on:
November 08, 2010, 08:11:35 PM »
I really dislike anything but the minimum cable freeplay, like 1-2mm or so travel measured at the grip. Makes a big difference to me. I would highly encourage you to tighten up the cable with the top adjuster and take it out for a spin.
BK
jchurch
Reply #37 on:
November 08, 2010, 08:28:43 PM »
Quote from: BK_856er on November 08, 2010, 08:11:35 PM
BK
BK , unfortunately as mentioned above the top adjuster is only for minor adjustments which still leaves me with 6-7mm. So tonight I will adjust the bottom one which is designed to achieve larger adjustments which it seems I require.
04 Aprilia RS125
BK_856er
Reply #38 on:
November 08, 2010, 08:48:10 PM »
Quote from: jchurch on November 08, 2010, 08:28:43 PM
Sorry didn't catch that, but as described they both accomplish the same thing, so adjust away and don't settle for anything less than perfection. If you end up with a high warm idle you've gone just a bit too far.
BK
jchurch
Reply #39 on:
November 08, 2010, 10:46:44 PM »
Quote from: BK_856er on November 08, 2010, 08:48:10 PM
BK
Cool just got home and sorted it. Much better now, Its about 1-2mm. Thanks for your help guys!
Last Edit: November 08, 2010, 10:52:37 PM by jchurch
04 Aprilia RS125
S2R 800 '07
Reply #40 on:
November 09, 2010, 12:47:59 AM »
Quote from: jchurch on November 08, 2010, 10:46:44 PM
[moto]
mattc7
Reply #41 on:
November 09, 2010, 08:08:18 PM »
Quote from: Raux on November 08, 2010, 09:48:44 AM
the Electraeon is a plus for me as it saves my wrist from being in an awkward position at full or 3/4 throttle where I do a lot of Autobahn riding.
but in town... it's touchy, but still smooth.
+10 for an 1100.
Excellent for the twisty stuff, and the track, and flogging it. A bit touchy in traffic. But so nice to whack wide open
