Sharing a Printer on a network
Started by the_Journeyman, July 21, 2010, 06:38:37 AM
Raux's suggestion wont work if you're running DHCP on PC #1.
We need more info from the OP.
Forget printing for a moment.  On PC #1 if you create a shared folder is it accessable from any of the other PCs?
Quote from: the_Journeyman on July 21, 2010, 06:38:37 AM
Machine # .... This is also the computer with the Canon iP3600 printer connected via USB.  It is also set up as a network/shared printer.
Set up as a network printer, how?  On the PC to which its cabled by USB it should be setup as a local printer and then shared.....
1) Are you running DHCP on any of the workstations?
2) Go to each PC > comand prompt > type "ipconfig /all"   and play spot the difference.....
3) Vista is a PITA.... piss it off for XP or 7.
Quote from: ungeheuer on July 21, 2010, 08:07:20 PM
^^  That wont work if he's running DHCP ... well it might work for a while until ip addy is reasigned....
then he only needs the computer (hostname) name on the network instead.
