November 24, 2024, 07:02:48 PM *
News: Please Help
Pages: 1 ... 15 16 [17] 18 19 ... 23   Go Down
Author Topic: [Introduction] Noob Q&A  (Read 46023 times)
Duc L'Smart
« Reply #240 on: December 30, 2010, 07:59:31 PM »
noticed today that on the ride to work that if i let the clutch out ANY at all and I mean like barely a hair it will start to roll the bike forward. also shifting has gotten rougher. Almost as if the clutch isn't engaging unless its pulled COMPLETELY back. Could this be the clutch going out or something that could be adjusted?
Have you bled the clutch? Could be old fluid, or air bubbles...
'07 1098s, '06 Paul Smart LE, '99 BMW K1200RS, '73 BMW R75/5, '67 Ducati Monza 250 Bevel Drive, '63 Vespa GS 160
xRANDOx
« Reply #241 on: December 30, 2010, 08:46:06 PM »
I've done nothing to the clutch
Ronr
« Reply #242 on: December 30, 2010, 08:57:43 PM »
Classic symptoms of a clutch needing to be bled.  I usually don't get much out of the slave cylinder (by the engine) but get quite a bit from the master cylinder (on the handlebar).  Very easy, and should fix you right up.
xRANDOx
« Reply #243 on: December 30, 2010, 09:26:03 PM »
How would I go about bleeding the master cylinder?
Ronr
« Reply #244 on: December 30, 2010, 09:50:53 PM »
There should be a little hex-headed nipple up there somewhere to stick a hose on.  That's where mine is, but it's likely different on various models.  If you don't see that, you can probably back off the banjo bolt where the hose attaches to the master, and catch the fluid with a rag.
Duc L'Smart
« Reply #245 on: December 31, 2010, 06:32:37 AM »
Like most things, it's simple once you know how to do it. Basically you add fresh fluid at the top of the system, & release the old fluid & air bubbles at the bottom. The stuff that comes out is caustic & yucky. If you don't want to have a Pro do it for you, at least ask for assistance from someone experienced the 1st time... A 6-pack might do it Grin chug
xRANDOx
« Reply #246 on: December 31, 2010, 03:49:34 PM »
All about learning to wrench on it myself. No offense but I hate paying people to do things I can do myself. That being said I do like to be shown how to do things the proper way and dont mind compensating for help  drink. However I don't think any of you guys are in the College station area.  Undecided I will be bringing the bike home this summer but I can't wait that long
muskrat
« Reply #247 on: December 31, 2010, 06:24:42 PM »
supply beer and cigars and some of us can probably find a "reason" to ride.  Cool
I'm a mechanical wizard.......wait, idiot, but I'll drink your beer.  chug
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
TresGatos
« Reply #248 on: December 31, 2010, 08:00:13 PM »
Just curious, do you have the only Duc in Bryan/CS?
When I've ridden mine to Jacksonvile I'm the only one.
'65 Honda CM91 - '98 Suzuki DR650 - '08 695+mods - '08 Hypermotard 1100S
xRANDOx
« Reply #249 on: January 01, 2011, 11:29:16 AM »
Yup, thought it was cool at first but now I'm starting to second guess myself  Undecided
loves ze desmodromics.
« Reply #250 on: January 01, 2011, 02:15:23 PM »
If you make sure to be patient, remind yourself that you don't know anything and take advice w a grain of salt you will be fine. If you charge in headstrong and impatiently work, things will usually not work out well. Avoid bonehead advice and read a lot, You'll be fine. They aren't cheap to keep, but it's been worth it.
xRANDOx
« Reply #251 on: January 01, 2011, 03:07:50 PM »
Been wrenching on my K5 blazer (mud toy) for 2 years now and I'm extremely hesitant with everything I do. I always make sure I know exactly what I'm doing. "Measure twice, cut once" I use that with everything I do.
muskrat
« Reply #252 on: January 01, 2011, 03:17:14 PM »
Hell, I've had six in five years and don't think they are terribly expensive other than the valve service.  It's worth the price just to ride an Italian IMO
2015 MTS 1200
09 Electra Glide
xRANDOx
« Reply #253 on: January 06, 2011, 12:01:05 PM »
Tried to take her around the block today, clutch isn't working at all now  Sad
hiero
« Reply #254 on: January 06, 2011, 12:42:33 PM »
so it's always engaged now?  Could you take a 5mm allen and remove the slave cylinder from the engine real quick and see what the condition of the slave cylinder and inner piston is?  If the slave was leaking, that could happen.
How much fluid is in the reservoir?
2000 Monster 750
1999 748
YELLOW!!
Pages: 1 ... 15 16 [17] 18 19 ... 23   Go Up
