February 13, 2025, 12:03:26 PM
Monster engine mount crack Help!!!
Topic: Monster engine mount crack Help!!! (Read 9608 times)
Re: Monster engine mount crack Help!!!
Reply #15 on:
July 26, 2010, 06:52:24 PM »
Disconnect the battery first, then the 2x large connectors into the ecu and there will be NO risk of blowing it when the welder is hooked up.
BUT, the real reason to remove from the frame is welding access. There simply won't be enough for a welder to do anything effective with the engine still in the frame.
Reply #16 on:
July 26, 2010, 07:00:56 PM »
what about the gauges? isnt that still grounded to the frame?
DarkStaR
Reply #17 on:
July 26, 2010, 09:23:50 PM »
Quote from: He Man on July 26, 2010, 07:00:56 PM
Doesn't really matter if the engine is removed from the frame.
pitbull
Reply #18 on:
July 28, 2010, 03:54:57 PM »
I've had two engines that have had cracked engine mounts.......one from a giant pot hole and another in a crashed bike I picked up for rebuild. Both engines I was able to get welded from a welder who works on race cars........charged me $100 each time.
Preisker
Reply #19 on:
July 30, 2010, 10:12:10 AM »
Find a welder that rides bikes, or race bikes, or builds race cars, someone that speaks the same language (motorhead) as you do. You might be able to get away with not pulling the engine, IF, the welder can get access to the mount that needs welding. If he can get his TIG torch in there. If it was mine, I'd pull it out of the frame, grind a pretty good V over the crack, and let Wilbur the Welder have at it. That looks like maybe a 15 minute job, if YOU prep the crack, you might get it done for a case of beer, or something of the sort. Doesn't look like a big job at all.
Reply #20 on:
July 30, 2010, 05:21:53 PM »
DOH
I just saw you are from NYC. European Cycle Services has experience with that repair.
http://www.europeancycleservices.com
You can trust those guys with your first born.
RetroSBK
Reply #21 on:
August 04, 2010, 07:33:56 AM »
Yep... lot of welders on here...
Come tell me how easy it is to "Just weld up" some porous, crappy, oil soaked cast alu in a stressed point, without preheating, or normalizing after the weld..
ROFl... God I love the internet!
Will Kenefick's Retro Superbike. Bringing you the sickest Sh*t since '94
Cati
Reply #22 on:
September 08, 2010, 02:48:57 PM »
Howie, I'm going to give these guy's a call there're out in Middletown, NY. I'm still riding at this point with the same crack. I'll be getting this fix soon.
Reply #23 on:
September 08, 2010, 02:59:36 PM »
Quote from: RetroSBK on August 04, 2010, 07:33:56 AM
Awww come on...
It's just like painting.
Anyone can do it.
RichD
Reply #24 on:
September 08, 2010, 05:26:49 PM »
...tell me how easy it is to "Just weld up" some porous, crappy, oil soaked cast alu in a stressed point, without preheating, or normalizing...
Sing it brother!!!
DFW-MFer!
TAftonomos
is without a monster :(
Reply #25 on:
September 08, 2010, 05:38:59 PM »
I know a monkey that can weld it up for sure.
Near Atlanta?
MyDucParts.com
Reply #26 on:
September 09, 2010, 12:44:32 PM »
Quote from: TAftonomos on September 08, 2010, 05:38:59 PM
Near Atlanta?
Does he do electrical on the side?
KnightofNi
Lift my kilt to see my
Reply #27 on:
September 09, 2010, 01:02:23 PM »
i had my engine mount welded up.
it survived a front flip and landed on the headlight/gauges after it bounced off of me.
Quote from: RB on September 09, 2009, 04:31:47 AM
Rob Hilding
Reply #28 on:
September 09, 2010, 01:10:20 PM »
WOW - Welding the engine mount causes front flips
Be careful out there
Düb Lüv
ASE master internet mechanic
Reply #29 on:
September 09, 2010, 05:31:06 PM »
Quote from: Cati on July 25, 2010, 06:03:14 AM
FIXED
ducatimonster.org
<--- that site's gay. it's ducatimonsterforum.org. DMF
http://giveme5ive.com/Ducati/IMG_0420.JPG
Last Edit: September 09, 2010, 05:33:01 PM by Düb Lüv
Building, building, building
