February 06, 2025, 03:50:02 PM *
News: Please Help
Author Topic: rotor thickness  (Read 1480 times)
« on: August 01, 2010, 09:23:36 AM »
What happens if you go past the minimum thickness of a rotor? Does it warp easier because its too thin to handle the heat?
DarkStaR
« Reply #1 on: August 01, 2010, 10:24:53 AM »
Quote from: Interwebs
Yes, thickness matters. Rotors must have enough meat to absorb and dissipate heat, and to maintain their structural integrity. Thin rotors are dangerous rotors that increase the risk of heat fade, cracking and failure. That is why most rotors have a "discard thickness" or "minimum machine to" specification on the casting. If you can't find it or the numbers are illegible, look up the spec in a service manual or electronic database.
Munch
Monster S4R - Munchstrada 1100S - 749R
« Reply #2 on: August 06, 2010, 06:47:04 PM »
I have a set off my 749R if you're looking for a used set...
redxblack
« Reply #3 on: August 06, 2010, 07:38:20 PM »
Aren't the stock 749 rotors different? I thought they were deeper insets on the carrier.
desmoworks
« Reply #4 on: August 06, 2010, 10:37:03 PM »
As compared to the Monster 1000 (that the original poster has) yes... 15mm offset (749/999) compared to 10mm for the Monster S2R1000.
Anthony Creek
Pro Italia Online || mota-lab
« Reply #5 on: August 06, 2010, 10:45:08 PM »
and 5 bolt vs 6 bolt for the S2R
Munch
« Reply #6 on: August 07, 2010, 07:30:59 AM »
Ya, these rotors are:
Outer Diameter 320mm
Inner Diameter 72mm
Thickness 5mm
Number Of Holes 5
Offset 15mm
