Rear caliper seizing help!
Started by AshyLarry, August 17, 2010, 06:51:04 PM
csorin
Quote from: Speeddog on August 23, 2010, 08:16:09 AM
The screw that sets the pedal position should have a nut on it to lock it in place.
Topic RESURRECTIOOOONNNNNN!!!!
I had the same problem here last week.  Rear brake seized up.  Lever wouldn't budge.  Turned out there was no play at all in the pedal.  My adjustment screw had backed way out and wasn't allowing any play.
I stopped by Lowes on the way to work and picked up some M5 nuts.  Turns out, they won't thread onto the adjustment screw.  Does anyone know what the screw size is?  It sure looked like an M5, but maybe I'm wrong.
Thanks guys.
All of the S*R and before Monsters, they're M6.
Not sure about the latest generation.
csorin
Quote from: Speeddog on September 19, 2011, 09:02:10 AM
You rock.  Thanks man.
H-2 CHARLIE
  Im going to check my freeplay now but a guy over on the beemer board tryied to adjust his rear pedal up to a higher mark ... his rear locked up and scared his rotor a bit ... freeplay
brad black
bmw guys are really good at screwing this up ime.
Brad The Bike Boy
http://www.bikeboy.org
