What are the issues if I have to use my stock exhausts with the DP ECU and Freeflow filter?
Why would you
NEED to run DP ECU and freeflow air filter?? If you need to run the stock cans..... do you not have a stock air filter and ECU you could use? Not that I think running with the DP ECU and freeflow filter will cause you any issues anyway.
It will be rich...
the stock exhaust might not flow as much as the filter and ecu are capable of delivering.
How will it be rich? If the DP ECU fuels the bike more than the stock ECU will not the greater capacity of the air filter to deliver..... more air.... compensate for that?? I think the stock exhaust will make as much fuelling difference to race ECU/freeflow filter combo as does the fitting of aftermarket cans to a bike running the stock ECU/air filter. And theres plenty of bikes getting around like that with seemingly with no detrimental issues.
