FHE 696 vs 696 w ABS?
Started by TWDucfan, August 26, 2010, 05:58:48 PM
TWDucfan
Anybody has first hand experience comparing ABS equipped 696 to non-ABS one? How well does ABS work?
Much appreciated  [bow_down].
Amlethae
I've had a 696 sans ABS, and now have an 1100 w/ABS... So I can kinda speak for it.
Differences?  Most of the time you won't be able to tell any difference.  But when the ABS kicks in, you know it.  I had to do a pseudo-emergency stop tonight because of stopped traffic on the other side of a blind corner... the ABS did not kick in and it shouldn't have.  If the ABS system sucked I would expect it to have kicked in for that.  But I've only found the ABS to activate when truly needed and I appreciate that about it.  You also have the option to turn it off if you'd like (for some odd reason) but you'd have to turn it off every time you got on the bike since it resets to the ON state when you cycle the ignition.
If you want to know anything more specifically let me know.
Also, if it's your first bike ever, don't get ABS... one must face the sausage creature in the mouth before you truly know the value of ABS.  Plus it's good to learn proper braking skills before you get some assistance.
Edward_Wolf
"Also, if it's your first bike ever, don't get ABS... one must face the sausage creature in the mouth before you truly know the value of ABS.  Plus it's good to learn proper braking skills before you get some assistance."
true.dat
8th - Ducati Streetfighter S (black) '10
7th - Ducati Hypermotard 1100s (Bayliss) '09
6th - Ducati 848 (Martini) '09
5th - Ducati Monster 796 (black) '10
4th - Ducati Monster 696+ (black) '09
3th - BMW R1100R (mistake)
2th - Ducati Monster 600 (Silver) '99
1th - Ducati Monster 600 (Black) '98
poseur
Quote from: Amlethae on August 26, 2010, 06:59:34 PM
I don't know about that. Braking without ABS is very different from braking with ABS. In cars, many people who drove cars for years before ABS find themselves modulating brake pressure when they should be just slamming the brake pedal. The same could happen with a motorcycle, in that you modulate/pump the brakes instead of just squeezing with all your might. ABS should allow you to steer while it's working too.
I don't know. Food for thought. If the ABS is good, you need to let it do its thing.
TWDucfan
Thanks for sharing the experience.  [clap]
Biggest concern is when something unexpected happens while riding and needs to stop quickly at less than idea road condition ABS might save the day. [beer]
i dont you just ride an ABS bike like a normal bike.
You shouldnt be modulating the brakes anyway. THe only difference is when your without ABS, you need to know when to stop applying brakes. when its too late, its too late. with ABS i thought you can just slam that sucker on and the ABS will find that limit for you...
steering with ABS on a BIKE?  no way. think about it. would you want pulsing brakes going through a corner on the edge of adhesion for your tires?
poseur
Quote from: Raux on August 26, 2010, 08:04:11 PM
Well, I've never tried it, and I wouldn't want to try it on my own bike, but in theory, it should work. In reality, in a panic situation, I doubt I'd be doing any steering though. Just filling my diaper while I grab a fist-full of brake.
Ddan
If you're braking that hard in a corner you've already screwed the pooch.  The ABS is only going to help keep the tire from locking.
Ducati Monster Forum at
www.ducatimonsterforum.org
Quote from: Dan on August 27, 2010, 01:01:09 AM
true
was illustrating I guess.
BUT trail braking... if you start to slide the tail in, would the ABS kick in or let you slide it through?
poseur
I wasn't referring to cornering, but steering to avoid something while hard braking.
Quote from: poseur on August 27, 2010, 06:43:38 AM
ABS just prevents you from locking up the wheel, you're still braking. Turning while braking is a bad plan. Either swerve to avoid something or brake-you can't do both at the same time-it's a recipe for washing out the front.
As far as the two in comparison, if the option was for the bike with ABS, one should absolutely get it.
One should also practice their emergency stops, either way.
V.rossi has built in ABS on his right hand.
jsd2
This video tests the ABS on the 1100 should be pretty similar.
Ducati Monster 1100 ABS - brake tested
Jim :)
ChrisH
Wow, that's really impressive! I could have used the ABS the other day as I drifted my bike sideways to avoid rear-ending a douche bag that slammed on his brakes for no reason. Alas, I didn't get ABS on my 696, but it still brakes well anyway :)
2010 Monster 696
2005 Honda Ruckus
1985 Honda Spree
-Austin Texas-
