February 06, 2025, 06:41:12 PM *
Pages: 1 [2]   Go Down
Author Topic: 696 wheel options  (Read 5261 times)
TrevOwnz
« Reply #15 on: September 06, 2010, 02:11:48 PM »
Does the 696 and 750 have the same exact rims?
1999 Ducati Monster 750
BK_856er
2007 M695; 2004 749s
« Reply #16 on: September 06, 2010, 02:21:22 PM »
I thought they had picked up the forms from another company.
you originally had the image with the other name on it for awhile until they sent new images.
so, the OZ's come with a new cush drive and sprocket carrier? is it AL as well?
Yep, the OZ dss wheel cush drive/sprocket carrier are pure billet aluminum goodness and use captive spacers.  Very light compared to the OE piece.  Sprocket hole pattern is different, so the Ducati sprocket won't transfer over.
The former wheel name was ITX.
BK
« Reply #17 on: September 06, 2010, 06:20:28 PM »
no
the 796 is a single sided swingarm
« Reply #18 on: September 06, 2010, 06:21:55 PM »
BK
oh see now you go and make it sound like such a great deal. time to start saving... although if I can convince Carrozeria to make a 4.5" rear, I'll go that direction
TrevOwnz
« Reply #19 on: September 06, 2010, 06:57:23 PM »
no
Not talking about the 796, I was talking about older M750s like the bike I own in my avatar. The 696 looks like it has the same rim. Anyone know if 5 spoke 696 rims will fit my M750?
« Reply #20 on: September 06, 2010, 07:21:20 PM »
woah
wow was I sleeping reading... sorry
moto
« Reply #21 on: September 08, 2010, 06:58:26 AM »
What year is your 750?
Monsters with double sided swingarms prior to 2002 used a 17mm rear axle. From 2002 on (with a couple exceptions) used 25 rear axles.
We should have both applications in stock.
-M
www.motowheels.com
96 M944
98 900SS FE
01 996R
02 MV Agusta F4 750
05 999R
06 SC1000
07 1098
08 M696
TrevOwnz
« Reply #22 on: September 08, 2010, 01:22:58 PM »
-M
Ok the site was working for me and I took at look at your prices, I think I will go a different route. Not willing to spend over a grand on a set of rims. I saw a set on ebay for 800.
Düb Lüv
ASE master internet mechanic
« Reply #23 on: September 08, 2010, 01:54:58 PM »
there's a set of 5 spoke marchesini on ebay. those are stock wheels off 1000ds monster, SS, and ST's. need to swap bearing or convert axles.
Building, building, building
moto
« Reply #24 on: September 08, 2010, 04:44:21 PM »
It is not too bad converting the front from 25 to 19mm- but it is a lot of work to convert the rear from 25mm to 17mm and make it line up correctly. The sprocket carrier has to be changed plus the spacing and chain offset. Our local machinist declined to convert a set over for us.
-M
www.motowheels.com
96 M944
98 900SS FE
01 996R
02 MV Agusta F4 750
05 999R
06 SC1000
07 1098
08 M696
Pages: 1 [2]   Go Up
