monsta rebuild
Started by monsta, September 05, 2010, 12:00:54 AM
truckinduc
How about a larger oil cooler instead of 2 separate ones?
This looks sweet.  Ill be removing all the sloppy casting marks off of my heads soon. Im also thinking about milling the belt guards off of the cylinders, no need for the extra weight.
Looking forward to progress.
monsta
Quote from: truckinduc on September 06, 2010, 04:31:21 PM
yeah, probably the way to go. hopeing I wont need it.
Got the cases back..
also, rounded the heads and polished the bag of stainless bolts in the pic!  :)  (I have a fetish for stainless)
Also got the heads mostly together today. Took me all day
monsta
Had a chat with the painter, he suggested that if I want to have this done for the Iatlian bike show on the 14 November, I better get the frame to him! So , thats what I've been doing...
got a bit done on the yesterday. Removed everything from the frame, while checkin it out when removed I found this..
I knew there was a crack there, but it had migrated round the back more than the front so it wasn't easily seen.
This is the worst side but the other side is cracked to.
I was planing to brace those area's.. maybe a timely rebuild..   :)
Duc796canada
Monsta indeed!! Cool stuff. That is one thing I wish I had, a machinist course, I work in aviation and see some of the cool stuff the "metal" guys get to make for themselves!! Great people to know :)
796 Red Monster(sans ABS)
Viz-Tec Supabrake II
15/41 gearing(AFAM quick change sprocket)
PC V, NEXTUP QS.
2006 Suzuki GSXR 600 track bike(I know...not a Duc...some day)
evoasis
I guess there are good and bad mods; you'll find the good ones here ;)
truckinduc
this is the style gusset ill be doing.
Quote from: Raux on September 15, 2010, 09:23:40 AM
freaking GORGEOUS
+1
monsta, mate how did I miss this one...?  What a beauty - I'm always impressed with (and yes a little jealous of) such machining skills  [thumbsup]
And the cases look fabulous - who coated em for you?  Was it a Victorian  8)?
Me? I'm welded on to this thread.....  [popcorn]
Mojo S2R
#24
Looks like it's going to be a real Monster  [thumbsup]  Looking forward to seeing more.   [popcorn]
monsta
trucka..  thats a classy looking gusset!
I thought about doing a curved one like yours, one of the things that stopped me was the fact that it would be difficult to make...  the scolloping out to fit the frame.  Well done!   [thumbsup]
I was also interested to see the pic that greenmonster posted in your thread of the Ducati Corsa 888  http://www.madeinitalymotorcycles.com/888corsa%20291107.jpg  I hadn't seen that before.
Ung..  I'm no machining superhero! I just know some good people to get advise from..  some of them here on this forum! :)
the cases were powdercoated here locally in Perth. No big deal I think any powdercoater could do it.. just textured black. The time consuming bit is the masking, took me hours, even made a cover for the oil filter sealing face.
anyhow...
making steady progress, I'm a bit time poor.
Made the gussets..
I was thinking of putting another gusset below the cross section mirroring the top one? Because frame work is a bit of a black art, I dont know if the extra bracing will affect the handling adversely?
anyone here have any thoughts?  I was just going to copy what others have done...
While playling around with the frame, these brackets fell off!!
I'd bolt that frame to the cases for the welding.
monsta
Quote from: Speeddog on September 17, 2010, 03:04:22 PM
yep, I've got a set of 999 cases I was planning to use.
truckinduc
Hey those same tabs fell off of my frame.
Looks good. Is that 4130 for the gussets?
Slow Guy
