monsta rebuild
Started by monsta, September 05, 2010, 12:00:54 AM
monsta
performance stuff
-984 big bore, dont know what the compression is, but runs ok on 95 octane fuel.
-ported heads
-standard 43/38 valve's (though longer for the cams)
-VeeTwo '210' torque cams
-Keihin 41mm carbs, long manifolds
-pod filters
-balanced crank
-machined lightened flywheel
-Ally clutch hub/ basket etc..
-Dyna mini coils
-ignitech ignition
other stuff
-ceramic coated piston crowns, combustion chamber and exhaust port (to keep the heat out)
-heat dispersing coating on heads/barrels
-low friction coated piston skirts
-modified oil galley to give cooling spray under rear piston
Rudemouthsky
Quote from: monsta on November 03, 2014, 02:49:51 AM
performance stuff
-ported heads
-pod filters
-balanced crank
-Dyna mini coils
-ignitech ignition
other stuff
Any noticeable difference with those new K&N open top filters?
monsta
one of these days, you should take some time to give that bike a proper wash ;)
lazylightnin717
Quote from: Grampa on November 03, 2014, 04:33:14 PM
[laugh]
I always love when this thread pops up. Seriously beautiful bike
Comes a time
Says don't you see
Gotta' make it somehow
Rudemouthsky
Quote from: monsta on November 08, 2010, 04:23:11 AM
stainless oil lines and banjo's..   and gold anodized gland nuts.
Yo Monsta G...if I may humbly ask you for yet another tip...would you happen to know the size and thread pitch of the alloy gland nuts? I'm looking to replace mine with some purty stainless ones like these:
And as usual I'm far from my home and bike parts when I get this bright idea...so can't check myself. I actually started a thread on this topic awhile back but nobody seemed to know.
I know the OE ones are brass with a plastic insert...did you make these yourself or source them?
monsta
monsta
oh...  and no I didn't make these. They are Vee Two items
What color is the body work?
What brand?
Tri stage?
monsta
Dont know DP. all I know is its called 'blood red' 2 pack
I could find out but, I'd just have to ring the painter...
EEL
I need to strip my forks as well. Is that type 2 or type 3 anodizing you got there. Do you know what the bike originally came with before you stripped?
Just curious. Don't put yourself out.
Looks great.
Rudemouthsky
