February 11, 2025, 01:22:17 PM *
Pages: 1 [2]   Go Down
Author Topic: Backfiring & ECU stuff.  (Read 5160 times)
Mr.S2R
« Reply #15 on: September 16, 2010, 10:45:20 PM »
Yes its a 2004 S4R, it started doing it when i put the mid pipe in and got a tune. Header gaskets were replaced and silastic around all fitment points so no exhaust leak.
Is that a termi system?  When you say mid pipe you mean you got rid of the cow udder (ie catastrophic convertor).I have a full termi system with no udder, straight through to the cans, and no flames!  Last time I saw flames come out of a Ducati was my old 650 Pantah.  It was running a 2 into 1 Verlicchi system - loud and shot impressive flames!  applause
cakeman
« Reply #16 on: September 16, 2010, 11:32:26 PM »
Yep, termi system, not full. I got rid of the cat and put the mid pipe in.
Im not sure if its me but feels like it might of lost a bit (power), but i have been riding like a hoon lately (just for testing purposes ofcourse Smiley )
Mr.S2R
« Reply #17 on: September 17, 2010, 12:21:55 AM »
ah ok - to me it sounds like the tune isnt right - when I had the Pantah it used to do the same.  I took it to a friend who balanced the carbies and it never did it again (little bummed at that!).  Cant remember if it is running too lean or rich (explain loss of power too) the fuel that isnt burnt correctly gets re-ignited in the hot exhaust - I am not positive and I am sure one of the sages on here will provide more appropriate and accurate advice.
could be worse - or maybe spectacular!!
R1_flames_Thanks_to_RgTeam_2.avi
« Last Edit: September 17, 2010, 12:24:51 AM by Mr.S2R » Logged
signora monster
« Reply #18 on: September 17, 2010, 02:03:58 AM »
Suzy, my 695 backfired and surged chronically when I bought it new. Since putting on the Termis, ECU and Air box, I have not had any probs at all. And I think it goes better. It may be the expensive option but it is awesome.  Grin
Monster + Termis = LOVE !!!!!!! drool
Mr.S2R
« Reply #19 on: September 17, 2010, 02:48:41 AM »
+1 AH-MEN!  laughingdp
brad black
« Reply #20 on: September 17, 2010, 05:33:17 PM »
i don't know what how the closed loop system actually works in terms of inplications when open loop, but the s2r1000 certainly ran differently with the sensor connected or not at wot.  so there is still some wot switching with regard to the lambda sensor, altho i don't think it's actually controlling the mixture.
the point at which is switches from open to closed loop on overrun could be the point at which is was backfiring too.  not sure of the mechanics of it.
i don't believe that unhooking the battery for a certain period will do anything to the adaptions on the marelli ecu.  i have seen a "reset adaptions" option on some of the models via the diagnostic tools, but it doesn't seem to be consistant across all models.  i have had ecu out of bikes for certain periods of time where things seem to have changed, but nothing i'd put any sort of confidence in.
it also may be related to what the fatduc actually does in terms of the input the ecu reads, how it's interpreted and the logic of that thru the software.
the location of the lambda sensor could also be an issue - it's on the front header?  as the rear is unsampled any variation between the two could lead to something like this.
i'm not sure what the make up of the newer shell 98 and 100 octane fuels are (i haven't seen the 100 locally for a while), but i mapped one of my bikes on the optimax when it first came out and when running on other brands of 98 the bike ran lean, especially at low throttle openings. i think i added about 20% to the just off closed throttle lines to get it back to where it was, and around 5% at high throttle openings.  so if they're still the same the extra richness at lower throttle openings could have an impact.  maybe ring shell and ask them, altho do it with an enquiring attitude, not a "your fuel is crap" attitude.
Brad The Bike Boy
http://www.bikeboy.org
suzyj
Does my bum look big on this?
« Reply #21 on: September 17, 2010, 08:12:25 PM »
Turns out it was all my imagination.  My bike ran beautifully today, never missed a beat.
heatherp
« Reply #22 on: September 17, 2010, 08:22:02 PM »
I'd say it was probably the fuel then.  I sometimes think mine is losing power and feels sluggish then I fill the tank with something else and all is okay again. I do have to use some questionable fuel at times, living and riding out in the sticks as I do.
cakeman
« Reply #23 on: September 17, 2010, 08:37:24 PM »
I usually put premium in mine but filled up with 95 instead today to see if the flames and back firing would settle down.......... didnt really
Mr.S2R
« Reply #24 on: September 19, 2010, 10:42:05 AM »
do you need the lambda sensor?  My S2R1000 has no cat - where the mid pipes are there is a balancing pipe with a spot where I guess a lambda sensor would be bolted in.  I have a DP ECU, open air box, and open pipes all the way through to the termis.  Never had the problems described here.  Always run BP Premium unleaded as I found the others left the bike a little off key - if that makes sense.
I am happy to put up some photos of my mid/balance pipe where the sensor is meant to be if anyone is interested.
 waytogo
Pages: 1 [2]   Go Up
