525 to 520
Started by scduc, October 01, 2010, 02:29:25 PM
Yes, 520 is lighter and cheaper.
It also wears out faster.
scduc
I guess the main reason is for the bling factor. I know I should get 20k easy on the stocker, but I'd like a better looking rear sprocket, carrier and hub. And while I'm doing that, might as well go for the lighter/cheaper option if not much strength and durability are sacrificed.
If you dont really take care of your chain and arent particularly harsh on your bike, im sure a 520 will do fine. i put 19k on the stock chain, lots of commuting. semi aggressive.
Is that including submersion in garbage?
Quote from: ducatiz on October 06, 2010, 03:58:12 AM
Not garbage - lubricating chicken grease. That's why his chain lasted so long [thumbsup]
Ai ya!  Mei gwan xi, Kui!
scduc
Quote from: He Man on October 05, 2010, 10:53:08 PM
You mean if I do take care of   Yes???
Duc796canada
Hmm! I learnt something, so if I replace my rear 39 tooth with a 41 tooth at my 600mi service, no need to change out the chain. I mean if a chain can last 10 t0 12k miles, 600 miles is a piss in the pond! Now, question is cush drives will the stock ones fit a new carrier? I'm going to go with a quick change combo(sprocket and carrier), thanks and sorry for jacking the thread:)
796 Red Monster(sans ABS)
Viz-Tec Supabrake II
15/41 gearing(AFAM quick change sprocket)
PC V, NEXTUP QS.
2006 Suzuki GSXR 600 track bike(I know...not a Duc...some day)
